Engineers
Old Mar 27, 2013 | 08:12 PM
basselope's Avatar
basselope
If you decide to go with stainless screen, get enough to make a few covers. 300 series stainless tends to be brittle and wont take much re-bending. It is often used for automotive exhaust plates and spacers because it is more corrosion resistant than bare steel, but is barely stainless and will rust in time, particularly in the presence of elevated heat.
As far as the opening, .0625" is 1/16 inch. I'd say you're plenty safe up to .125" [1/8 inch].
Old Mar 27, 2013 | 08:38 PM
zwildman's Avatar
zwildman
Originally Posted by sgdiesel
In terms of the free area ratio, it is very simplistic and misleading to assume a 50% ratio equates to 50% air flow, that is simply not the case. In fact, I would suggest that you would be closer to seeing no reduction than you would to seeing a 50% reduction. What will happen is that in the area of the screen the air will accelerate through the screen and then decelerate once it is through the screen. There will be a marginal air pressure increase on the front face of the mesh.
In terms of mechanical strength, providing you leave sufficient gap between the screen and the rad you should be fine (I would suggest 1/2" as a rough guide). By the time the stone has broken through the mesh (if it even does) you will have dissipated that much energy that I doubt there will be sufficient energy left to damage the rad. Worst case you may need to cut another piece of screen and replace. The tensile strength of stainless braid is incredibly high.
In terms if 316 vs 304, agree with above, 316 is stronger but both are perfectly adequate for your application
This is a great analysis, especially the part about leaving a gap which was my first thought. Whatever you place in front of the cooler will also flex when hit with enough force. A 4 ounce rock at 30 mph will exert several pounds of force when it hits the mesh (I'm being lazy, can someone calculate that easily? LOL F=M*A) so even a piece of 1/16 inch thick sheet metal placed directly on top of the fins would transmit some force to the fins. Leaving a gap and holding the edges of the mesh tightly will prevent the "rebound" from reaching the fins.
I also have to agree strongly that the 50% coverage will not relate to 50% reduction in airflow. After all, air filters do work and probably have greater than 50% coverage.
I would go with the 316 for the slightly better corrosion resistance and for being somewhat stronger (more for corrosion since you're in Vermont), the price difference is probably marginal between the two. You'll have far more labor in making the piece and mounting it properly than the difference in the cost of the two materials in the same area.
Old Mar 27, 2013 | 08:49 PM
zwildman's Avatar
zwildman
Just did the comparison, Corrosion-Resistant 304 SS Woven Wire Cloth 3 X 3 Mesh, .063" Wire Diameter is $28.69 for a 12" x 24" piece and Super-Corrosion-Resistant 316 SS Wire Cloth Woven, 3 X 3 Mesh, .063" Wire Diameter is $39.06. No brainer.
Old Mar 27, 2013 | 09:13 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Your solution is to stop that rock before it can get to the oil cooler. Your answer is an extended front fender flap OR relocate a different oil cooler up on the one of the fork tubes.
Old Mar 27, 2013 | 09:21 PM
Eshaw301's Avatar
Eshaw301
Originally Posted by FLTR2008TRIKE
I would suggest installing a fender mudflap to help protect your oil cooler
Old Mar 28, 2013 | 03:19 AM
Theatan's Avatar
Theatan
Rick,
Use the 304 Grade of Stainless Steel. It is a general purpose industrial grade. Where as the 316 Stainless Steel is used for manufacturing food processing and medical processing equipment/machinery. The 304 is tougher and has better wear resistance. Where as the 316 is held to a higher level of metalurgical compsitional purity thereby costing more to manufacture.
Old Mar 28, 2013 | 06:33 AM
Rickr01's Avatar
Rickr01
I love this place! Thanks Guys!
Old Mar 28, 2013 | 06:43 AM
Scrmnvtwins's Avatar
Scrmnvtwins
First I would suggest that your cooler is designed for 100% open area and the screens you have proposed will be taking away your coolers ability to cool the oil. I don't see where you have identified the wire Guage or dimeter but have specified opening sizes with 25% to 52% open area. Imagine if you will that your oil is a huge heat sink and the more restrictive you cooler screen is the less the cooler is able to cool the oil. Also the oil will continue to have heat added by the motor and eponentially the heat stored in the oil will overtake the coolers abilities. FYI the followign chart is provided but I would really think about the disadvantages of restricting your coolers air flow.
Old Mar 28, 2013 | 07:34 AM
DavidStiebel's Avatar
DavidStiebel
Try some stainless window screen, it is strong durable and lets air through.
Old Mar 28, 2013 | 12:08 PM
grbrown's Avatar
grbrown
Setting aside why you feel the need for an engineer or an oil cooler, where is this being installed on your bike? Can we have a photo or link, so we can size up the problem? deflecting debris using baffles is more desirable than part covering the cooler with a screen, I suggest.
