Rear Hoop Bar delete options for FLHT
Old Mar 31, 2013 | 11:06 AM
Houlie's Avatar
Houlie
Thank you guys, Have a Safe and Happy Easter
Old Mar 31, 2013 | 09:05 PM
GaugeMods's Avatar
GaugeMods
Former Sponsor
Originally Posted by hog-doc
I used pike nuts after cutting the bar off just past the strut covers on my Road King and Street Glide.
Hog-doc: What did you do to keep the Pike nuts in place? Threaded rod? What size Pike Nuts did you use?
I also like 2kids3pets mod but at a 140.00 ..... I'm looking to do it on the cheap.....too bad it just wasn't a insert for the cut off bar.
Old Apr 1, 2013 | 03:52 AM
painey's Avatar
painey
Is there any reason NOT to do this mod? i.e. stability?
Thinking about doing stretched bags and fender and removing the 'hoop' sure would improve the looks, but as I also do long roadtrips with a tour pac and 2-up wondered it removing the hoop could affect stability?
Old Apr 1, 2013 | 09:29 AM
GaugeMods's Avatar
GaugeMods
Former Sponsor
There are many company's that make brkts to eliminate the hoop, Baddad sells one for about 80.00 the Auto Gem shotgun's for a 140.00 and you get led's that will work as a brake light after you hook them up.
But none is cheaper than the Hacksaw and Pike nuts. You can't just remove the hoop although It connects with with Bag braces I believe or something.
Old Apr 1, 2013 | 09:33 AM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
All the hoop does is hold the lp.
Old Apr 1, 2013 | 09:40 AM
GaugeMods's Avatar
GaugeMods
Former Sponsor
It does more than just that. It connects to the chrome that runs down to hold up the bags. You can'y just remove it without replacing it with something, or hack sawing the the hoop off. My LP don't even hook to the hoop.
Old Apr 1, 2013 | 09:44 AM
gmc's Avatar
gmc
You can eliminate that bar completely. Cycle Vision and Drag Specalties makes a License Plate Bar Eliminator.
https://www.denniskirk.com/search/li...+eliminator+.q
I use Klock-Werks upper filler which comes with this plate. Removing the loop doesn't cause any stability problems, I've ridden 50k miles without one.
Old Apr 1, 2013 | 10:03 AM
IAMSWUTIAMS
So there.
Old Apr 2, 2013 | 11:34 AM
Houlie's Avatar
Houlie
So there.
....X2
Old Jan 28, 2023 | 02:09 PM
Sweetricky6804's Avatar
Sweetricky6804
I realize this thread is ten years old but I’m trying to eliminate this bar….seems like a lot of stuff is discontinued… can anyone help me locate a set?
tru510
Jan 29, 2023 08:20 PM
streetglide4567
Aug 7, 2017 11:01 PM
SGLarry
Oct 6, 2014 06:01 PM
G9803
Jul 18, 2014 12:56 PM
vgibbs
Apr 21, 2013 09:33 AM
