Boom Amp Install Question
Old Mar 30, 2013 | 09:35 PM
Bo Joe's Avatar
Bo Joe
Default Boom Amp Install Question
I'm trying to install the amp on my 2012 Street Glide with the standard radio. Do I need the radio wire harness - part no. 69200106.
Old Mar 30, 2013 | 10:22 PM
Bo Joe's Avatar
Bo Joe
I think I might have figured it out. This is my six-way Deutsch audio housing and since it isn't plugged into anything, then according to the instructions, I need the wire harness 69200106.
If the black six-way housing [6B] is NOT connected to a harness, install a radio wire harness (Part No. 69200106, purchased separately) as follows:...)
Also I noticed on the six-way that there are two free open spots for wires. I'm assuming that's where I put the two wires from the amp wire harness. Also looking at the two free wires and the plug that suppose to go into the six-way, one wire is yellow with a brown strip and the other is yellow with an orange strip. I'm assuming I just need to make sure they match up.
Old Mar 30, 2013 | 10:35 PM
txharley11's Avatar
txharley11
When I installed mine I had to purchase the harness for the ultra before the amp would correctly connect. You then have the wires for the rear speakers if you ever need them
Good luck
murph
Audio Systems
May 20, 2017 07:37 PM
Jimmy55TX
Audio Systems
Mar 31, 2017 10:59 PM
robert.schoelkopf@gmail.com
Audio Systems
Oct 30, 2015 10:21 AM
UltraClassicWNY
Audio Systems
Oct 26, 2015 09:45 AM
gpp
Nov 30, 2012 06:42 PM
