Floor Board problem
Old Apr 8, 2013 | 02:44 AM
OPDSam30's Avatar
OPDSam30
Default Floor Board problem
Can anyone tell me why my right side floor board sits lower than my left. The left side is level but the right side rides lower. Is there a stopper or a wedge that keeps them level?
Old Apr 8, 2013 | 03:11 AM
Def Mute's Avatar
Def Mute
We can give you man suggestions...
As far as what to look for, but no one can tell you what it is without looking at the bike in question. If you don't have a lift, get down on your hands and knees and look at the mounts. Are they aligned at the same level on frame? There is an adjustment for that ya know? Are the brackets, or the foot boards warn where they make contact? Did a fat *** step on the right side foot board and bend it?
Only you have what is necessary to tell exactly why they are not right...
And that is, the bike sitting in front of you to inspect for the cause.
Old Apr 8, 2013 | 08:41 AM
grbrown's Avatar
grbrown
On my bike there are three optional mounting points for the front board mounting. Check as Def Mute suggested, to see if yours are both mounted in the same hole. The holes are joined together, so you just have to back off the screw a few turns, slide to the chosen hole and tighten up. Simples!
Old Apr 8, 2013 | 09:43 AM
mrfuji's Avatar
mrfuji
Default floor
hi.old frame 08 less have fews holes in frame to adjust the angle.09 newer 1 hole if you have floor board extension.usualy have a small screw to adjust the angle. pitch in -out .mrfuji
Old Apr 8, 2013 | 09:46 AM
RPS1981's Avatar
RPS1981
Bent bracket from being dropped? Not in same mounting holes on both sides?
Old Apr 8, 2013 | 09:48 AM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
That's my guess too.
worked4it
Feb 3, 2019 02:28 PM
Ventana
Mar 27, 2017 11:19 AM
mikelikesbikes
Apr 27, 2013 02:19 PM
lefty971
Jan 1, 2012 07:24 AM
saxmanbill
May 18, 2009 06:09 AM
