Best driving lights
I'm just not overly impressed with the amount of light the stock HD foglights put out.
As far as brightness - fog lights aren't supposed to be driving lights, so they are expected to be dimmer. On the other hand, I can see your point about wanting them brighter.
Even after my somewhat negative thoughts, I would be interested in pics if anyone does any of those mods to the passing lights - more light in the early mornings would be great!
Not sure which one you installed but the spot light unit specs are unbelievable. note that distances are in meters not feet. Beam distance of over 1000 feet! As mentioned earlier, it's Lux at specified distances and not raw Lumens which is most important:
Weight (lbs): 1
Watts: 20
AMP Draw: 1.45
LED's: 4
Lm / LED @ 25C: 392
Raw Lumens: 1,568
Lux @ 10m: 490
Beam Distance (m): 442.7
Peak Beam Intensity (cd): 49,000
Operating Temperature: -40ş ~ +145ş Fahrenheit
Width: 5" (4.960)
Height: 1-5/6" (1.840)
Depth: 2-1/4" (2.250)
By the way, for those like me who don't have access to fabrication methods, the Harley wind deflector (air damn) that mounts between the triple trees ($29.99) might be used to mount instead of a bracket. I'm going to give it a try. When I do, i'll try to post some pics. Still concerned about the fender hitting it though but it might raise up the light about 1/2 to 3/4 inch and back a bit.
In any event, thanks for the post, Ed. Have a great smokey mountain trip.
I know there is some concern as to whether there is enough clearance between the light and fender. I'll let you know in a couple weeks when I return from a 2000 mile trip to Skyline/BRP/Cherohala.
I also purchased the yellow cover which diffuses about 30%. The covers were relatively inexpensive and hopefully good for the rain and fog.
Here are some pics:
Good trip?
How did light perform?
Clif
Great trip - 8 days from NJ, down Skyline Drive, Blue Ridge Pkwy, Diamond Back, Tail of the Dragon, part of Moonshiner, etc, etc.
Didn't use the light all that much on the trip because most of the trip was during the daylight hours.
But I did test some more after I got back. This works great with the Phase 7 LED light. I really can see far and wide. I had to angle the Rigid Industries light further down than I thought orignally - maybe because it is mounted upside down. And I'll have to figure a better light switch position because as much as I thought it would be convenient being near but tucked by the gas tank, it is not as accessible as I would like it to be. But for now it is ok.
Now the bad news - it does hit hit the fender. As much as me and a buddy of mine originally thought differently, we were both proven wrong. When I checked the travel specs for my bike, it was something like 4 1/2 inches. I had close to 4 inches so I thought I was safe - NOT! As you can see from the pics below, the dent I now have is about 1/2 inch deep. The dent from the front is not very noticable - you can see it better from the top.
I do not believe it will get any worse (I have put on another 300 miles since the trip and it has remained the same). The dent is elliptical and very symmetrical in shape and as much as I don't want it there, it doesn't bother me much. I'll do something with it during the winter (not riding season).
When I get a chance, I'll take some pics of the lighted view so you can see how much light it puts out.
Glad you had a great Smokey Mountain area trip. I'm on my way there on June 1st for my annual spring trip.
Thanks for taking the time to post and bummer about the fender.
You mentioned you are looking for a better switch location. This is an excellent choice which I've been using for a long time for Lazerstar lights mounted on my engine guards. The switch is black and mounts to the left handlebar switch housing. Can't even notice it and it's within thumb reach. Very high quality relay too.
http://www.lazerstarlights.com/parts...1054_1062_1128
[IMG]//http://www.lazerstarlights.com/images/OPTIMIZED/LSW1010_V1.PNG[/IMG]
