Primary oil
Old Feb 18, 2007 | 08:05 PM
choochoo's Avatar
choochoo
Default RE: Primary oil
Any good quality reputable synthetic is fine.
Valvoline, castrol, V-twin, mobil, amsoil
as long as they meet or beat the manufacturers specs your warranty will remain intact.
Same with your filters.
I've been running Castrol and or valvoline in all my bikes, and cars / trucks since the 60's.
Never had an oil related issue.
Old Feb 18, 2007 | 08:41 PM
iclick's Avatar
iclick
Regarding Formula+, I can't see spending $6.50/qt. for what's basically an unexceptional 10w30 semi-synthetic motor oil with a dab of EP for tranny use and little else. I think you can do as well with a cheap fossil oil at Walmart for $1/qt. The primary isn't rocket science, and the only function for the oil is to cool the primary chain and clutch plates. I've heard of people who've forgotten to fill the primary after draining and after running the bike for a week sustained no discernible damage. I'm not recommending this, of course, but the point is that most anything will work, whether motor oil, ATF, MTL, or whatever. At the moment I'm using Castrol GTX 20w50. It works fine and is only $2/qt.
FWIW, I would never use Formula+ in the tranny, despite HD's recommendation. Use a quality synthetic in the engine (15w50 or 20w50) and 75w90 gear oil in the tranny. Heavier gear oil in the tranny shouldn't hurt anything, although I'm not sure we need it.
Old Feb 18, 2007 | 09:53 PM
SteveO's Avatar
SteveO
Amsoil motorcycle 20W50 in all three holes. 15,000 happy miles! 75,000 miles on my 01!
Got better things to do than worry about oil! Go with what is recommended by HD, use a good 100% synthetic , then you can sleep better at night!!!!!
My .02 worth!
SteveO
Old Feb 18, 2007 | 10:16 PM
01Ultra's Avatar
01Ultra
I use HD synthetic in primary and engine and Bel-Ray in tranny.
Old Feb 18, 2007 | 10:27 PM
Jakes's Avatar
Jakes
6th Gear
ORIGINAL: iclick
Regarding Formula+, I can't see spending $6.50/qt. for what's basically an unexceptional 10w30 semi-synthetic motor oil with a dab of EP for tranny use and little else. I think you can do as well with a cheap fossil oil at Walmart for $1/qt. The primary isn't rocket science, and the only function for the oil is to cool the primary chain and clutch plates. .....snip......
[sm=exactly.gif]Primary oil is there "primarily" to cool the clutch and add the minor lubrication the chain needs. Don't waste your money on expensive synthetic in there.
I use Mobile 1:20w50 in the motor and Mobil 1: Syn Gear lube 70w95 in the tranny. Any good quality 10w40in the primary (whatever I have on hand for my cars). For all you youngsters out there, H-D's original dino primary oil (no longer available) was 10w40.
Old Feb 18, 2007 | 11:25 PM
jeepster09's Avatar
jeepster09
Cool....an oil question....haven't seen this subject brought up before.[8D]
Old Feb 18, 2007 | 11:53 PM
bay13's Avatar
bay13
Engine: Redline 60w20 for summer, 50W20 for winter
Transmission: Redline Shockproof Heavy
Primary: Redline MTL
draggingframe13
May 24, 2013 03:53 PM
richmac64
Oil Archive (no new posts)
Feb 3, 2013 12:37 PM
Roofighter
Apr 22, 2008 08:19 AM
Road Glider
May 6, 2007 04:27 PM
Popeye47
Apr 1, 2005 03:34 PM
