Normal exhaust flow?
Old Feb 17, 2007 | 08:45 PM
HOOSIER's Avatar
HOOSIER
Default Normal exhaust flow?
I traded my FLSTC in about 2 weeks ago on a new FLHTCU. The dealer installed Vance and Hines Oval slip-ons the day of purchase. Today I was standing behind the bike while it wasrunning to listen the sound and I put my hand close to the exhaust. I noticed that the right side had a lot more flow coming out of it than the left side did. I know there is a "crossover pipe" butis this normal? I figured that crossover would equal out flow??? I have never owned a bike where the exhuast pipes come out both sides...
Old Feb 17, 2007 | 08:50 PM
StreetGlide2006's Avatar
StreetGlide2006
Default RE: Normal exhaust flow?
With the stock headers the crossover will put more flow and sound both out the right side.
Ride Safe,
Mike
Old Feb 17, 2007 | 09:23 PM
mrsr71's Avatar
mrsr71
ORIGINAL: StreetGlide2006
Ride Safe,
Mike
How come?
Dan
Old Feb 17, 2007 | 09:27 PM
HOOSIER's Avatar
HOOSIER
ORIGINAL: mrsr71
Ride Safe,
Mike
How come?
Dan
Old Feb 17, 2007 | 09:28 PM
cbwat1's Avatar
cbwat1
Put true duals on it and get rid of the cross over. I think it looks better and helps the bike run cooler too.
Old Feb 17, 2007 | 09:45 PM
wesd41's Avatar
wesd41
ORIGINAL: mrsr71
Ride Safe,
Mike
How come?
Dan
The left side exhaust pipe joins the right side pipe (exiting the rear cylinder) at a 90 degree angle. Air doesn't like to turn corners, especially if it has the option of going straight.
Old Feb 17, 2007 | 09:50 PM
johnny canuck's Avatar
johnny canuck
This is normal. The factory header is essentialy a 2:1 system. It will deliver more TQ & HP with the Ovals than a true dual system. Stick with it. At idle, if you put a handkerchief close to the left exhaust (looking from the rear), you may see the cloth sucked inward slightly due to negative pressure.
Did the dealer change the air cleaner to a high flow system?
Some dealers are taking shortcuts and doing a HD Digital Tech "race flash" along with a hi flow cleaner. This is not the correct route. You need to install an EFI mapping system..PCIII or SERT for example.
Old Feb 17, 2007 | 10:10 PM
HOOSIER's Avatar
HOOSIER
ORIGINAL: johnny canuck
The dealer did not install a high flow air cleaner. They talked me out of thatand I dont remember why.. The only thing done to the bike was slip-ons...Is this "race flash" the same as the "download"? Does a EFI mapping system void the warranty?
Old Feb 17, 2007 | 10:22 PM
sims5's Avatar
sims5
Unless you live where there is smart air it just won't turn the corner to come out the left side as much.
Old Feb 20, 2007 | 12:28 AM
suprdve's Avatar
suprdve
3rd Gear
These guys are right. Normal exhaust flow. I'd look into a download and high flow air cleaner though.
