Gearbox fluid level
Old Apr 16, 2013 | 06:55 AM
grbrown's Avatar
grbrown
Brilliant idea for the dip stick 2kids3pets!
jrat69, the 'quart' referred to as trans capacity is a guide, not the absolute quantity. We get a steady trickle of similar threads about what is the correct amount of oil, when the answer is to fill it in accordance with the level recommended - however much that requires! Sometimes it is a little less than the quoted amount, sometimes a little more.
Old Apr 16, 2013 | 07:33 AM
btsom's Avatar
btsom
Anybody have enough knowledge to hazard a guess as to whether the drilled holes might weaken the dip stick and allow vibration to cause a piece to break off? Back in 08 there were a few threads about unmodified dip sticks breaking off and causing havoc in the transmissions. Perhaps I worry too much, but those threads convinced me to cut off the dip stick, now that piece is just a plug. I fabricated a maintenance dip stick with an equivalent level reference which I keep with the other specialized maintenance stuff.
Old Apr 16, 2013 | 07:50 AM
texaswiz's Avatar
texaswiz
Originally Posted by texaswiz
We have no idea what you are riding but we will assume for the moment it is a touring bike. If you set the stick on the top of the threads and it does not show full, then add lube until it does show full. My experience has been that it is really hard to see new gear lube on that shiny stick. I paint mine black.
Sorry, I should have mentioned what I painted it with. This does not have to be a complicated procedure to work well. I pulled the dipstick out and wiped it down using some paint thinner. Rubbing alcohol would work just as well, but I would have had to go into the house to get that. After a few minutes of drying time I sprayed the stick with some rattle can primer. You could use any color. primer is just what was handy at the moment. It has held up good for 4 years and makes it a lot easier to see transmission lube on the stick.
Bye the way, I think the Harley engineering department went a little overboard when they chromed the dipstick.
Old Apr 16, 2013 | 08:25 AM
jrat69's Avatar
jrat69
2012 Road King, and the redline does show up real well on the very bottom of the stick. I assumed (yes I Know what that means) that posting in the Touring bike section, but one never knows.
Thanks for all the replies, I'll add a little more.
We have no idea what you are riding but we will assume for the moment it is a touring bike. If you set the stick on the top of the threads and it does not show full, then add lube until it does show full. My experience has been that it is really hard to see new gear lube on that shiny stick. I paint mine primer color.
Old Apr 16, 2013 | 08:54 AM
kyote's Avatar
kyote
I highly doubt that would ever happen.. the stick is thick enough in those areas not drilled. The only way it would break off MAYBE would be if there was SEVERE vibration and it was whipping back & forth.. MAYBE.....
JackKnife5
General Topics/Tech Tips
Jul 10, 2018 07:28 PM
Shep68
Nov 27, 2013 02:54 PM
2000fxdl
Jan 30, 2013 03:10 AM
2007fxdc
Jul 14, 2009 08:42 AM
spizzyman
Aug 21, 2008 11:20 AM
