Starting trouble
Old Apr 16, 2013 | 12:42 PM
wildsting's Avatar
wildsting
Default Starting trouble
I just got my bike all set up for the nice weather, it fired up first time no problem, after a few starts it was having trouble firing and I thought it may be the 5 year old battery so I bought a new one put it in and I am have trouble starting the bike
when i turn it over sometimes it will catch and turn other times it sort of humms then clicks a few times then catches , starter or solenoid.
I know its going to get worse before it gets better
Thanks
Ron
Old Apr 16, 2013 | 01:04 PM
mrfikser's Avatar
mrfikser
check your ground to the frame..when I say check it I mean take it off and clean it and reinstall it...also check where the wires go onto the starter....
Old Apr 16, 2013 | 04:38 PM
wildsting's Avatar
wildsting
Will do & thanks
Old Apr 16, 2013 | 05:20 PM
Ragtop's Avatar
Ragtop
yup, sounds like a bad ground
Old Apr 16, 2013 | 06:52 PM
Juice's Avatar
Juice
Yes. +2 on the ground wire.. But probably time for a battery too.
Old Apr 16, 2013 | 07:55 PM
kyote's Avatar
kyote
Ditto.. and he said he already bought a new one...
Old Apr 16, 2013 | 08:31 PM
Chicota's Avatar
Chicota
I agree not that it matters but I had the same problem on an electra glide purchase a kit to rebuild solenoid but it turned out to be bad gnd.
Old Apr 21, 2013 | 06:29 PM
wildsting's Avatar
wildsting
grounds all check out cleaned everything put it all back together tried starting and al I got was starter spin think it is starter clutch
Old May 5, 2013 | 06:08 PM
wildsting's Avatar
wildsting
All done changer starter clutch went for a ride 2blocks from HD dealer blew a hose to my oil cooler what a mess got them to fix it and now Im a happy camper (biker)
Thanks for all the help
Oldschool
Old May 5, 2013 | 06:14 PM
vbx07's Avatar
vbx07
Check the wiring on your fuel injectors under the tank. I had the same issue and the wire was chafed. Disregard wrong thread
bluharley
EVO
47
Feb 20, 2014 07:01 PM
racerx143
Aug 27, 2013 09:08 AM
oil leak
Sep 2, 2010 09:17 PM
2kanzam
Jun 27, 2010 04:37 PM
tmf2
Jul 31, 2007 10:03 AM
