rattlle
Old Apr 18, 2013 | 12:20 PM
FOCI's Avatar
FOCI
Default rattlle
running i have what sounds like a loose fuel cap but i checked it and the cap is tight . Should i replace the cap or should i be looking some where else for my cause?
Old Apr 18, 2013 | 12:43 PM
mkguitar's Avatar
mkguitar
all the time, sometimes ?
what speed, what rpm ?
to track things down you have to figure out the conditions under which you have a problem...it is RPM related or road speed related ?
etc.
could the dash be loose ? the gas tank, something else ?
mike
Old Apr 18, 2013 | 01:26 PM
grbrown's Avatar
grbrown
Why replace the cap if it is tight?! It may be something else in that area. Keep looking.
Old Apr 18, 2013 | 01:27 PM
FOCI's Avatar
FOCI
thanks i will be looking further into it .
Old Apr 19, 2013 | 05:46 PM
Teachinator's Avatar
Teachinator
I was chasing a gremlin rattle for months. I put a piece of tape on my gremlin bell and the noise stopped. Relocated the bell aft no more rattle.
Ph
Old Apr 19, 2013 | 05:50 PM
RoadHog659's Avatar
RoadHog659
What does a loose fuel cap sound like? Do you happen to have the push-button fuel door?
Old Apr 19, 2013 | 06:42 PM
Keithhu's Avatar
Keithhu
If you have a Road King, it sounds like a buzzing noise when you get into higher RPMs, you can stop it by putting your hand on it. I had this problem when I had a Road King, its why I went to the flush mount, drove me nuts
Old May 2, 2014 | 11:56 AM
FOCI's Avatar
FOCI
the rattle only happens from 1/2 tank of fuel and below does not happen when it is over a 1/2 a tank.
Old May 2, 2014 | 12:27 PM
mkguitar's Avatar
mkguitar
I'd guess that the fuel pump or hose is contacting the tank when level is low.
or a pinholed fuel line is spraying in the tank
but that's a guess
mike
inswva
Sep 7, 2010 02:28 PM
Explorer
Jun 14, 2010 06:26 AM
1unclejojo
Shovelhead
Aug 12, 2008 06:22 PM
upnorthbiker
Dec 2, 2007 06:29 PM
Ex11b
Oct 24, 2006 12:50 AM
