Engine troubles Help
Old Apr 26, 2013 | 09:53 PM
soft 02's Avatar
soft 02
Did you look closely at your internal fuel lines and your fuel pressure regulator???
Old Apr 26, 2013 | 10:21 PM
SpiderPig's Avatar
SpiderPig
Originally Posted by Foodog2
My 06 ultra died like that and it was inner cam bearings. I woukd have sworn it was a electrical problem like only running on one cyl. I hope you are luckier than me.
When my inner cam bearing came apart it acted the same way. Took out the motor as well. Good luck I hope it is something as simple as the coil.
Old Apr 26, 2013 | 10:31 PM
ke5rbd's Avatar
ke5rbd
I would run a compression test and it it is ok, I would put a timing light on the rear cylinder and see if it is firing steady. If this checks out and no vacuum leaks, I would suspect an injector. I also wouldn't use WD40 as it can get in connectors and cause havoc. I speak from experience. A propane torch not burning would be better. A vacuum leak and poor firing can cause the fire from the throttle body. I also have seen a blown head gasket kill a cylinder. It sounds like a bad exhaust leak, but can be covered by loud exhaust. The compression test will detect this. I also wouldn't go to far before looking in the cam chest as problems in there can wipe out the engine real quick.
Old Apr 27, 2013 | 05:56 AM
BIGRED1's Avatar
BIGRED1
Had an ignition module go south once and it was doing the same.
Quite possible that when cam chest was re-installed a wire might have been pinched and thru vibration caused a short.
Just something else to check.
Old Apr 29, 2013 | 05:35 AM
Ben A's Avatar
Ben A
Got home from Leesburg yesterday and pulled the engine codes and got only 2 codes P1353 and P1356 Front cylinder no combustion and rear cylinder no combustion. I started it once and both exhaust get hot so what is the code telling me?
Old Apr 29, 2013 | 08:05 AM
kojak's Avatar
kojak
Seen many posts on these codes. Most fix by checking plugs, plug wires, ecm to injector wire (near plugs), possible coil issue. It could be a intermittent problem due to a break in the wires for instance.
Old May 20, 2013 | 05:19 AM
Ben A's Avatar
Ben A
Ok finally got this problem solved. It turned out to be a cracked fuel pump. Not enough fuel pressure to keep it running. Thanks for all the help. Ben
Old May 23, 2013 | 08:10 PM
Ben A's Avatar
Ben A
Actually it was the fuel pressure regulator that had a crack in it. Any way back on the road again
Old May 23, 2013 | 08:17 PM
soft 02's Avatar
soft 02
Cool.
HOGILAC
Apr 10, 2018 09:17 PM
MrCancilla
Aug 12, 2014 08:47 PM
french harley lover
Shovelhead
13
Sep 25, 2013 08:45 AM
Tommy-Law
Sep 4, 2013 06:17 PM
Ben A
Apr 22, 2013 09:55 AM
