A little help with oil temp please
Old May 1, 2013 | 03:41 PM
iclick's Avatar
iclick
Originally Posted by EasTexUltra12
Does someone make a fan for the OEM oil cooler? I hadn't heard that and would be interested in that.
I don't know of any. I tried fabricating small fans for the cooler but couldn't get any to last more than about six months, as it's a very hostile environment down there--heat, water, debris thrown up by the front tire, etc. They did work moderately well when they were working, though, but didn't completely stall OT's when stationary. They would climb, just not as fast. I have no plans of trying the fabricate oil-cooler fan(s) again, but if I did I would try to shoehorn a 4" Spal fan behind the cooler by retooling the VR and cooler brackets.
I added a Ward FCS (head fans) last year at the beginning of the summer and that made a huge difference in engine cooling. I monitor FCHT (front cyl. head temp) with my Power Vision display unit, and last summer in S. LA I never saw FCHT exceed 250° and OT exceed 225°, even in traffic. So far this spring I've seen peaks of 235° for FCHT and 210° OT. I would recommend the FCS to anyone regardless of whether they're having heat-related problems or not. It doesn't directly cool the oil, but controls the head temperature which is the hottest area the oil flows in. OT still climbs slowly, but not as fast and does not peak as high. Once hot it also takes much less time to recover once you get moving since the head is cooler.
Website
HDForums thread
Old May 1, 2013 | 05:01 PM
jammerx's Avatar
jammerx
I have the Jagg Fan Assisted 10 row oil cooler and a Andrews 57H. I believe the camshaft has played a significant part in my cooler running. I am still running the catalytic converter. I have the fan switched, so it only runs when I turn it on. I think the cam has had a major impact on engine temps. I will let you know mid summer...
Old May 1, 2013 | 05:36 PM
Delta's Avatar
Delta
Originally Posted by rufasim
No, the back jug definatly shut down. It was stop and go traffic and the engine oil temp was 270. At what temp does it turn off the jug
On my trike the temp was set at 284*. On a chocked up motor it doesn't take long in Boston's stop & go traffic to get to that temp. I also have the Wardspartswerks fans, like iClick, and for the money is a great way to manage the heat being generated. I can come off the highway with a front cyl head temp of 270* and then sit in stop & go traffic and watch the temp decrease to 255* with these fans.
Old May 1, 2013 | 09:23 PM
bklynbob's Avatar
bklynbob
Get a Wards parts Werks low temp thermostat for your cooler. $25 to lower oil temp 15 degrees is a bargain.
Old May 1, 2013 | 10:44 PM
smithbrl's Avatar
smithbrl
I have the FCS fans also. I can let the bike idle til the EITMS kicks in then turn the fans on and a minute or so later both cylinders are firing again. Cooler heads=cooler oil temp, I guess. All I know about my oil temp is that it's HOT!
Old May 12, 2013 | 01:01 PM
tjjtande11's Avatar
tjjtande11
5th Gear
running a 103 with the oil cooler fuel moto tuned PC-V tuner with autotune oil temp gauge in the fairing normally running 240 to 250 plus when pushing it from what I have seen it kicks out the read cylinder even at 230 when I stop, bike is running slightly on the rich side to compensate, my buddy running with me has a Victory Cross Country Tour runs 30 degrees cooler
exemexer
Apr 30, 2013 01:00 PM
1sweetglide08
Dec 19, 2012 04:41 PM
car5car
Exhaust System Topics
13
Dec 20, 2009 06:37 PM
twitchy
Jul 15, 2009 02:38 PM
roadking1893
Mar 9, 2009 10:51 AM
