Fairing Pouch Spacers - Needed?
Old May 1, 2013 | 07:14 PM
Dobe66's Avatar
Dobe66
Default Fairing Pouch Spacers - Needed?
Installed the HD 3-pocket fairing pouch and it came with spacers that fit between the outer and inner fairing. Kind of makes sense as the pouch material could compress over time and allow the three windshield screws to become loose. The only problem is that they don't allow room to loosen the windshield screws to swap out different shields and I'm worried that they'll drop between the fairing halves if I pull screws all the way out. Are these spacers really necessary?
Old May 1, 2013 | 07:40 PM
Pa-Rider's Avatar
Pa-Rider
If you're talking about the 3 round rubber feet that come with the kit? Those are feet that go between the bottom metal part of the pouches and the top of your inner fairing to stop the kit from rubbing on your inner fairing. I could be mistaken, but that's what I got with my kit when I bought it.
Old May 1, 2013 | 07:45 PM
Nute's Avatar
Nute
Yup! That's where mine were used. Also keeps it from rattling.
Old May 1, 2013 | 08:26 PM
Dobe66's Avatar
Dobe66
Can't remember at this point, but I think the pouches had built in little feet. These are alluminum (?) spacers that you have to hold in place as you insert the three windshield screws before reinstalling the windshield and then the pouch. After everything was secured, the spacers appear to fill the space in the windshield cut outs.
Old May 1, 2013 | 08:32 PM
EasTexUltra12's Avatar
EasTexUltra12
You should have gotten 3 longer screws as well. Hold the spacer in place with needle nose, start the screws, then install your shield and pouch set. Easy. I used the spacers on my pouch install. I figure they included them for a reason.
Ride Safe
David
Old May 1, 2013 | 08:35 PM
Cowboy Rob's Avatar
Cowboy Rob
Big Kahuna HDF Member
This is the version I think you are talking about. The rubber stick on feet were used on the older three pocket pouch that sat on top of the inner fairing. TexUltra nailed it on the install.
http://www.harley-davidson.com/gma/g...ersion=desktop
Old May 2, 2013 | 12:12 AM
Dobe66's Avatar
Dobe66
TexUltra did nail the install. Went just like he said. Now the question is, how do you switch shields without dropping those little spacers. Can't grab them with a needle nose now because they ride in the windshield cutouts.
Old May 2, 2013 | 12:53 AM
claytucc3's Avatar
claytucc3
I do not use the spacers and have no rattle. I switch windshields often and did not want to deal with them!
Old May 2, 2013 | 04:13 AM
EasTexUltra12
Yes you can, and just as easy. Loosen the 3 screws, remove the pouch set, wiggle the shield back and forth while pulling up on it. It'll pop out. Then reverse all that to install the new shield. Don't forget, there is no reason to remove the screws to change shields. Just loosen them.
Ride Safe
David
Old May 2, 2013 | 07:30 AM
batman4706's Avatar
batman4706
How about gluing them on with weatherstrip adhesive?
