Brake light switch
Old Feb 20, 2007 | 02:38 PM
GMONEY220's Avatar
GMONEY220
Default Brake light switch
I believe my switch is bad.No worky with either brake and swapped brake relay with starter,and bike fires right up.
I dont want to leave my bike at the dealer for a week for this darn switch.Wandering if it'spossible for them to give me the part under warranty?Anyone have luck with the service department on warranty items,or do i have to let them do it?
It's a fairly simple install.
Old Feb 20, 2007 | 02:48 PM
Tech2's Avatar
Tech2
Default RE: Brake light switch
ORIGINAL: GMONEY220
I believe my switch is bad.No worky with either brake...
Are you saying that the brake light does not come on with either the pedal or the lever? If so, that doesn't sound like a bad switch.
Old Feb 20, 2007 | 02:50 PM
sleepneagle's Avatar
sleepneagle
I thinks you better try a bulb.
Old Feb 20, 2007 | 03:31 PM
godshd's Avatar
godshd
ORIGINAL: sleepneagle
If that does not work then jump the switch with a single wire and turn the bike on light should light when jumped. If it lights with the switch jumped then the switch is bad. However thereare 2 switches one for back brake and on for front. Never known a dealer to give you a part to put on under warranty then they loose money on the hours worked.
Old Feb 20, 2007 | 03:36 PM
SteelCityScooter's Avatar
SteelCityScooter
As mentioned above, you have two brake switches, and it is pretty uncommon for BOTH to fail at once. you already checked one common factor (relay) the other three are the fuse, bulb , wiring. (May want to check plug at top of back fender also.
And probably first you should try the fuse......... if you have cruise installed, if it works fuse ok if not fuse blown. (Same fuse circuit is Brake/Cruise on RK)
Fuse is under left side cover, cable end of fuse block, top fuse, 15 amp
Mike Simeone
EVO
Aug 26, 2018 08:52 AM
newmanb138
2014-2024 Touring Models
Apr 27, 2017 08:15 AM
Average bob
Oct 10, 2011 12:15 PM
pistole
EVO
Feb 8, 2010 06:20 AM
Rynb15
Apr 15, 2007 10:30 AM
