TGS Test
Old May 13, 2013 | 11:22 AM
Rwhnze's Avatar
Rwhnze
Stage III
Default TGS Test
Is there an electronic test for the twist grip sensor ie ohm meter?
I'm getting the dreaded error code 1510 & 2138. Codes wont clear, tried recalibrating TGS still wont allow me clear codes.
Old May 13, 2013 | 07:56 PM
dansflhti's Avatar
dansflhti
A couple weeks ago while on a ride I had the same issue.I was able to get going again by disconnecting the the connector on the side of the throttle body and reseating it a couple times.You could do an ohm check by finding the 6-place molex #204A,inner fairing-right radio support bracket.
Constant resistance between pins,4-6,3-1
variable with twist grip between 5-6,4-5,1-2,2-3.
Measure resistance on connector going to the TG,not to the ECM and TCA.
Old May 13, 2013 | 08:48 PM
dansflhti's Avatar
dansflhti
Not sure if my reply showed up.
Old May 14, 2013 | 02:11 PM
dansflhti's Avatar
dansflhti
bump up
mplazz
Apr 9, 2018 02:20 PM
470004
Audio Systems
May 18, 2016 10:46 AM
Harleyonthebrain
Sep 4, 2013 05:15 PM
champ198
Oct 12, 2010 01:06 AM
lady biker
Jul 7, 2006 09:13 PM
