Noisy synthetic
Old May 15, 2013 | 10:35 AM
  #31
Climb14er's Avatar
Climb14er
Redline 20w-50 quieted the sewing machine sound of the 103 down even more than the Mobil V-Twin 20w-50 did.
Old May 15, 2013 | 11:03 PM
  #32
taconite's Avatar
taconite
Lubrication formulation is a compromise. No one type or blend of oil is best at every type of lubrication regime. A synthetic can be formulated with additive packages to simulate and exceed what a mineral oil can do in terms of hydro lubrication modes. But you can not change the fact that its basic make up is homogenized. Its only as good as long as it stays together in other words. Synthetics long chain molecules shear and do not go back together well. When this happens they drop the additive package molecule that was bonded to it. 5K later the oil is thin, less viscous . The contaminants fall out of suspension, and it separates into its root elements once again. Mineral oil on the other hand because of its natural randomization will kind of re-bond after shearing. It is so good at this it grabs the dirt, carbon and other stuff and keeps it as well. Thats why old mineral oil is thick when you drain it. It increases in viscosity with shear cycles and contaminants. To simplify things it's kind of like OSB strand board. All the random size chips of wood in OSB give it its strength. You can crack it , bend it and it wants to stay together. its tough stuff, its not the best looking or the most refined, it takes on water, dirt and swells, but its strong. Plywood on the other hand is very smooth, refined, stable and strong till you break it once. Synthetics are great for precise controlled lubrication tasks, where you can formulate a package to achieve a specific engineered situation or event. A Harley engine is far from that, its a controlled disaster at best. It's to dumb for a smart oil. Just change your Dino oil when it's dirty, it will do everything you need.
Old May 16, 2013 | 05:44 AM
  #33
bundy43's Avatar
bundy43
Originally Posted by Teardrop
Installing lifters is not bad at all if you have adjustable push rods. I have Gaterman's 1023 lifters I just picked up that I will be installing Memorial weekend. Will let you know how they turn out when I test them out.
Will be interested in results,I think that is why they are so noisy,cheap lifter and push rods not held to spec,oil has nothing to do with it if they will stay pumped up,just my 2pennies
Old May 16, 2013 | 06:08 AM
  #34
Notgrownup's Avatar
Notgrownup
I have run a variety of syn's since 1000 miles and never looked back...The pipes trump the engine...if it's noisy it's running...
Old May 16, 2013 | 08:03 AM
  #35
Sprinter7x's Avatar
Sprinter7x
+1 Very well put!
Old May 16, 2013 | 09:39 AM
  #36
Wild Card's Avatar
Wild Card
X2...very well said.
on the other hand...where has the OP gone? He stirs the pot with uneducated and childish comments and has flown the coupe.
I been called worse by better
Old May 16, 2013 | 10:49 AM
  #37
beary's Avatar
beary
Originally Posted by Sprinter7x
+1 Very well put!
Yes, this is all true. Still there are many many studies that compare syn and mineral oils and they all come to about the same conclusion that additives in mineral oils break down faster than in syn oil, especially in the higher heat. The problem with that is the multi-viscosity oils loose their viscosity flexibility and eventually the oil hangs around one viscosity. I observed the test results a few years ago where the life of the additives in mineral oil was about half the life of synthetic. So mineral oils need to be changed more often than synthetic to achieve the same performance and protection.
While I agree oil should be changed when it looks dirty, looks aren’t always indicative to the additives breakdown. Most research conclusions are about the same in suggesting that mineral oil should to be changed between 1500 and 3000 miles while synthetic is between 3000 and 5000 miles. If you ride in higher temp climates like I do in in Oklahoma, then sooner is better.
My point isn’t to suggest that synthetic should be your oil of choice, I am very satisfied with mineral oils. I only use synthetic for the high heat.
Beary
tmac00333
Oil Archive (no new posts)
27
Jun 9, 2019 06:32 AM
Hardreef
May 7, 2013 05:59 PM
soft 02
Nov 2, 2010 07:24 AM
Jim Kraft
Mar 15, 2010 10:17 PM
sedbiker62
19
Jul 12, 2006 09:21 AM
