Locking Gas Cover
Old May 18, 2013 | 10:45 PM
SubZer0's Avatar
SubZer0
I've done it myself on my 05 Road Glide (before a fob was needed). Took off for a ride, stopped in the gas station to tank up, duo no key. Prayed all the way home to get my key. To this day I still double check then triple check to make sure I have my key with me.
Old May 18, 2013 | 11:52 PM
mkguitar's Avatar
mkguitar
Key and Fob zip tied to the top of my riding boot.
easy
zip tie breaks, they fall into the boot.
Mike
Old May 19, 2013 | 12:09 AM
cb7263's Avatar
cb7263
Originally Posted by dedjr67
Just for future knowledge you can unlock the fuel door on an ultra with any round Harley key does not have to be the same key as the ignition.
Didn't know that, nor did I ever think about it. Nice to know, thanks!
Old May 19, 2013 | 12:31 AM
Joltergeist's Avatar
Joltergeist
Originally Posted by mkguitar
and when the push button fails...( like on my bike), you can remove the dash to access the filler on recent model...on earlier models you can use a brass feeler gauge to release the catch...will only take 40 minutes or so.
the push button in a POS.
the brass pin in the linkage can vibrate out of place- and then you are sunk...800 miles from home 30 miles of gas range left and the gas station closes for the night in an hour.
you may like it now...but one day you may have my experience.
mike
That, and the comfort knowing no one can easily siphon off your tank...
Old May 19, 2013 | 01:01 AM
rpking's Avatar
rpking
I always take my key with me, I always lock my saddle bags and ignition when I stop
the key fits in my pants pocket just fine
Old May 19, 2013 | 01:06 AM
2AMGuy's Avatar
2AMGuy
Community Influencer
One of the first things that I did to my 2000 Ultra was a push-button gas door lock.
However in time the "spring" (a flat piece of srping steel) lost it's flexibility and would not push the gas door lid up enough to open and I had to resort to using a credit card to pry the lid up.
Finally, while on a long trip the spring broke so I was forced to find a replacement spring.
I ended up at a Wal-Mart where they had a two-pack of 9V batteries on sale and they were cheaper ($ 4.95) than buying only one battery.
You should have seen the look on the saleman's face when I told him that all I wanted was the little coil spring and that if he would cut it off for me that he could have both of the batteries!
That spring was on my bike when I sold it last fall and occasionally I'd have to give it a little pull to make sure it would open the lid.
Old May 19, 2013 | 09:00 AM
KAUFMANSM's Avatar
KAUFMANSM
I had the push button release on my last 2 ultras with no issues. Just installed 1 on my street glide but did notice the hinge spring set up was now different. Looks like a better set up.
Old May 19, 2013 | 11:02 AM
TWIN CAM 96's Avatar
TWIN CAM 96
Buy a lanyard & keep it around your neck can't forget that.
bigdaddy33
Aug 26, 2014 06:41 PM
wdcamp
Jul 18, 2008 09:36 PM
Gunkholes
Aug 14, 2007 07:42 PM
Arvid
Jul 5, 2007 08:37 PM
Garemlin
Nov 1, 2006 11:44 PM
