Busted case
Old May 20, 2013 | 07:01 PM
bagman1's Avatar
bagman1
AHH, that plug looks like it had red locktite on the threads.
Old May 20, 2013 | 08:01 PM
dougbk's Avatar
dougbk
For new cases with matching numbers and labor I do not think that estimate is that far off. I had to recase my 89 due to a cracking by the rocker blocks. I used S&S cases.
Old May 20, 2013 | 08:07 PM
soft 02's Avatar
soft 02
Order the cases and do it yourself. Its not any more difficult to split the cases than to do a set of cams. Just more nuts and bolts.
Old May 20, 2013 | 08:15 PM
davessworks's Avatar
davessworks
Originally Posted by Ultra103
Is that a tapered plug? Might explain things.
Yeah - that . . .
Damn - don't over tighten these buggers.
Old May 20, 2013 | 08:30 PM
waltz4's Avatar
waltz4
Default Yes, you can save the cases !
I used to work with a guy in Madison, FL. Victor Hutcherson, Hutcherson Machine Shop, 7213 Florida 14 Madison, FL 32340. If you pull the motor out, clean the cases and the pieces of all the oil that you can. Victor can weld them up for you and possibly weld you a bung so you can screw a new plug in. Good luck !
(850) 973-3141
Old May 20, 2013 | 09:04 PM
piesik650's Avatar
piesik650
My buddy made this mistake on his fat boy. it didn't break the pieces off it just cracked it and leaked. I ground it out with a dremel and JB welded. but yours is a more extreme case. bummer dude.
Old May 20, 2013 | 10:37 PM
rkcmike63's Avatar
rkcmike63
Originally Posted by anotherblacksg
yep, my dealer mentioned this plug when i went in for oil this weekend. The parts guy said i needed xxx quarts and i told him that it never takes what the manual says. His explanation was that there's always about 1/2 qt left in the bottom of the motor and the only way to get it all out is to remove (break) that plug. But never remove that plug because it's expensive as hell to get it back together. It would appear that you learned that the hard way...
yes!!!
Old May 20, 2013 | 10:49 PM
my67pnycar's Avatar
my67pnycar
Man that sux. Maybe he can try motorcycle salvage yards, might be able to get a cheap case to rebuild with the parts out of his old motor. Wish ya'll luck.
Old May 20, 2013 | 11:48 PM
lh4x4's Avatar
lh4x4
If used cases can't be found www.ketterharleyonline.com has roughly 20% off, no sales tax(so far) and free shipping on HD parts over $99. If you don't have the part number the web site has a phone number to get help.
Old May 21, 2013 | 03:56 AM
grbrown's Avatar
grbrown
Reminds me of my shovel - the exhaust threads on both heads broke away and a local drag racer repaired them and put helicoil inserts in. So a competent welder can probably repair those cases. He could also weld that hole up to get rid of that drain plug! My Evo doesn't have one.
