Busted case
Old May 21, 2013 | 05:25 AM
dansflhti's Avatar
dansflhti
Is that the same hole where you would install the sensor for an oil temp gauge?
Old May 21, 2013 | 06:14 AM
valvestem's Avatar
valvestem
No it is not.
And I go with the fellows who said get it welded, but the engine still has to come out etc. So you are looking at a lot of work.
Old May 21, 2013 | 07:29 AM
2kids3pets's Avatar
2kids3pets
Sometime you save money doing it yourself and sometime you don't.
Some people should just put the tools away.
Old May 21, 2013 | 01:58 PM
rkcmike63's Avatar
rkcmike63
Don't know about that. It is a plug used when an engine problem is suspected with the crank or bearings. Supposedly you pull the plug to see if there are metal shavings before you tear an engine down...
Old May 21, 2013 | 03:05 PM
hardheaded's Avatar
hardheaded
what about pulling the battery and drain the fluids, maybe even pull exhaust and lay bike over on some carpet or something soft and weld. as long as you got a good view of it , it could be done. just has to be very clean.
Old May 21, 2013 | 03:14 PM
kyote's Avatar
kyote
or a lift...
Old May 21, 2013 | 03:18 PM
Jackie Paper's Avatar
Jackie Paper
Before I spent $3200, I would talk to a good welder. I wrote procedures for a couple years for weld repairs (just the machine end of prep) for submarine and air craft carrier parts. It's weldable. Forget glue unless it just a 35 mph around home bike.
Old May 21, 2013 | 03:42 PM
Ragtop's Avatar
Ragtop
Whatever he decides, advise him not do the work!
Some people should stay way from wrenches...
Old May 21, 2013 | 03:52 PM
fastglass's Avatar
fastglass
Check out the S&S cases.
Old May 21, 2013 | 03:59 PM
dribble's Avatar
dribble
Originally Posted by rkcmike63
I have a friend with a busted engine case on a 2006 Screaming Eagle Fat Boy. It broke when trying to install the crank case plug... Harley wants over $3200 to get new cases and install. And the dealer is not budging any on the price.. Money is tight, any ideas? Does not appear to be able to be welded... The bike is still at his house. Going to call a few other dealers..
Anyone know a great Indy in the South Georgia or North Florida area?
Ride safe,
Mike
He can buy an exchange rebuilt (basically new) black & chrome engine from HD for about $3095.00 and install it himself if he is mechanical at all. If not he can pay an indy about 500.00 to install it. No core charge for the busted case and it will come with his original engine numbers. Been there and done it.
