He can buy an exchange rebuilt (basically new) black & chrome engine from HD for about $3095.00 and install it himself if he is mechanical at all. If not he can pay an indy about 500.00 to install it. No core charge for the busted case and it will come with his original engine numbers. Been there and done it.
Isnt the SE engine cases a dark grey and not black?
The service manual does say not to remove this plug.... But why not? Why would our exhaulted and reveried Harley Davidson engineers leave dirty oil in the crankcase without a way to remove it. The guys ( I don't remember his name) premise was sound...On an oil change...Lets get ALL the dirty oil out that we can. Why leave contaminates when there is this handy dandy plug here that would drain it all. It seems to me that the broken plug should be the primary, and the one that leaves a 1/2 quart if dirty oil in my engine should be the one that you "do not use"
Always wondered why that plug was on my softail? But I never touched it. Yeah you can't over tighten a steel tapered plug in an aluminum case never end's well.
I used to work with a guy in Madison, FL. Victor Hutcherson, Hutcherson Machine Shop, 7213 Florida 14 Madison, FL 32340. If you pull the motor out, clean the cases and the pieces of all the oil that you can. Victor can weld them up for you and possibly weld you a bung so you can screw a new plug in. Good luck !
(850) 973-3141
This , cases are like any other cast aluminium part it can be welded , shaped and redrilled & tapped . What do you think us old broke knuckle draggers did when things broke ? Spent the next 4 months rent & grocery money on new **** ?
everything going great till the last 1/4" then you hit a sand cast defect.
making your own welding rod from grenaded cast off cast Harley aluminum pieces.
nope never had the pleasure
