Inner Primary Bearing Replacement How-To
Old May 20, 2013 | 08:02 PM
xwhyz1959's Avatar
xwhyz1959
Originally Posted by captsluggo
Not sure which one you are talking about. The IPB is sure enough an outer race with the rollers visible. It comes off with the inner primary. The inner race will be on the mainshaft and can be pulled with a special tool or cut.
My bad, all I seen was he wants to change the IPB, missed the race. Whats wrong with the race? Discolored? Rough? If it's not hurt, why bother with it?
Old May 20, 2013 | 11:26 PM
ke5rbd's Avatar
ke5rbd
On the ones I have seen the inner race is what goes bad. It is also a HD part only. No one piece kit available for 2008 up. 2007 and older you can get a one piece sealed bearing retro fit kit. They changed to metric size shaft and outer race size. It is also an odd ball size. Bearing house I talked to said it was proprietary and nothing would fit it other than the HD bearing.
Old May 21, 2013 | 01:34 AM
imskier2's Avatar
imskier2
Here are some pics
Attached Thumbnails Inner Primary Bearing Replacement How-To-inner-pri-bearing_0001.jpg   Inner Primary Bearing Replacement How-To-inner-pri-bearing_0002.jpg   Inner Primary Bearing Replacement How-To-inner-pri-bearing_0003.jpg   Inner Primary Bearing Replacement How-To-inner-pri-bearing_0005.jpg
Old May 21, 2013 | 07:33 AM
mr396's Avatar
mr396
Does this kit look good?
http://www.jpcycles.com/product/602-731
Old May 21, 2013 | 08:50 AM
1Felix1's Avatar
1Felix1
Originally Posted by Duracell
Not sure what an arbor press will do but you will probably want to get an inner race bearing installer tool.
I just replaced the ipb in my 07. I ordered the inner race removal tool from amazon for $59. Turned out that the race had walked up the shaft and was too close to the pully for my new removal tool to work. Ended up cutting the race and splitting it with a chisel. You will need the race installation tool to reinstall the new race. I believe you can purchase it separately from the removal tool. By the way Harley wants $195 for their removal and install tool. Go figure.
Good luck
Old May 21, 2013 | 01:44 PM
Duracell's Avatar
Duracell
$135 from George's Tools
I have several of his tools, good quality stuff a little cheaper.
Old May 21, 2013 | 06:08 PM
xwhyz1959's Avatar
xwhyz1959
You still need a press for the bearing itself, unless this tool handles that as well.
gsequel1
13
May 24, 2023 10:03 PM
Wyatt MacGregor
EVO
16
Mar 29, 2017 09:07 AM
DMetcalf
Sep 11, 2015 03:46 PM
scglide
Oct 12, 2013 01:46 PM
CroK
General Topics/Tech Tips
Oct 15, 2009 03:52 PM
