Well we had a scary ride a few nights ago. Two lane back road, slowed down to turn left and heard tires braking hard behind us. No damage but pretty scary. Would like to light up the back better but the 2010 doesn't have the center large light. Any ideas would be appreciated.
High quaily LED's like. Radiantz lighting and plasma rods
BBERK will be SEEN!
When he's rearended it'll be because the teener was texting or talking...
There are a host of good LED products available that will do the job. Several were mentioned above. A quick search for 'motorcycle LED taillights' will produce a smorgasboard of choices including some that are not as good as the better ones you'll see on the forum or uToob... good luck.
I've got a combination of panacea and custom dynamics I've moved from a couple of bikes, and gonna add some radiant...
Here's my CD Plasma Rod install on a 09 FLHX & your 2010 can be wired easier (plugs to tail/tri harness) and set-up for tail/brake/turn. These definitely illuminate the rear. Enjoy!
