Engine guys help please
Old May 31, 2013 | 03:43 PM
  #141
flhxmc's Avatar
flhxmc
Originally Posted by nomad billy
Well gents thanks for the suggestions and help.I have officially entered myself into the dumbass of the month contest and possibly the year.After tearing into the bike with determination, missing a very good ride ,spending a relatively small amount of money on parts and gaskets I found the missing oil.While contemplating pulling the trans looking for a possible crack in the transfer tubes running through the trans a friend suggested closing my eyes and repeating all my steps.We then repeated them,conclusion,I pulled the wrong plug and drained my oil,what I read on the stick had hung there overnight and when I started it the pump sucked in that 1/3 of a qt I added allowing the light to go out momentarily,it came on when I walked away.
Changing the transfer hoses was maybe needed,maybe not,finding one tensioner going bad was also ok but nothing I found would have stopped the ride, my hard head was at fault.
Thanks again and remember,assume nothing as this leading contender for DA of the month has proven.
Glad you figured it out. We all make mistakes.
Old May 31, 2013 | 05:05 PM
  #142
Joe2010ultra's Avatar
Joe2010ultra
wait now I am confused. If you drained the oil and filled it and it is empty, there is still 4 Qts missing? I was never good at if the train was going one way and the other was going a different way math. Anyone else doing the math?
Old May 31, 2013 | 05:21 PM
  #143
chester1957's Avatar
chester1957
I read your posts carefully and don't understand, at what point did you re-drain the fresh engine oil, when you were changing the tranny oil?
Old May 31, 2013 | 05:24 PM
  #144
Joe2010ultra
What he said !!!! Glad I am not the only one confused.
Old May 31, 2013 | 06:30 PM
  #145
turnerbend's Avatar
turnerbend
Sound like you been on a 7 day drunk, sober up, think about it, and just say it didn't happen.
Old May 31, 2013 | 08:30 PM
  #146
Def Mute's Avatar
Def Mute
Don't light the pipe...
until AFTER the work is done, and maybe a good test ride. THEN we can PAAARRRRTAY!!!
Old May 31, 2013 | 09:31 PM
  #147
waltz4's Avatar
waltz4
Default Strippers ?
See. Didn't I suggest you go hang out with some new strippers and get your mind off of this for one night. Then go back, drain everything and make sure you refill with correct amounts and a new filter. Bingo. Problem solved. Nothing like a night of carousing and hitting the strip joints to clear your mind and make every little thing alright again. Glad you found your error and corrected it.
Old May 31, 2013 | 09:46 PM
  #148
SpiderPig's Avatar
SpiderPig
Originally Posted by SpiderPig
Step 1
Drain each hole and measure what comes out. If each area has the correct fluid measurrment for that component continue. If not post what you find and we will try and help.
Step 2
Before proceeding install a new filter
Step 3
Refill each hole with correct amount of flluid
Step 4
Run again for 10 minutes and recheck everything
MMMM lets see I seem to have read this solution somewhere. Now let me think a bit, it will come to me soon Im sure.............
Old Jun 1, 2013 | 01:48 AM
  #149
Joker65's Avatar
Joker65
That was worth 15 fkn pages!!! Yawn....
Old Jun 1, 2013 | 08:35 AM
  #150
Chuck1's Avatar
Chuck1
Glad it wasn't serious but after pictures of drain plugs and everything...............dang.
