broken spring on starter button
Old May 25, 2013 | 10:39 AM
Fl Jimbo 05's Avatar
Fl Jimbo 05
Default Broken spring on starter button, $1.98 fix
anyone else have this problem? The replacement cost for this spring is $69.95, because u have to a whole new switch. This is on an 05 RK, but I'm pretty sure all these switches are the same. Anyone know of an aftermarket spring or an easier fix? Thanks in advance for any help.
Yep, 3/16 x 3" toggle bolt with spring loaded butterfly ends that go thru wallboard did the trick. found at local hardware store. Simply remove the spring, bend the ends over and install. I used 2 of them for added strength.
cost of part - $1.98
time spent on toilet thinking of this idea - priceless
Old May 25, 2013 | 11:41 AM
0ldhippie's Avatar
0ldhippie
Check ebay/indy/dealer for some take-off switches. Not a common problem.
Old May 25, 2013 | 01:47 PM
mkguitar's Avatar
mkguitar
you could replace the solenoid end cover for one with a plunger ( ebay about $25).
This simplifies the starting system, taking the handlebar switch, relay and wiring out of the equation.
Mike
Old Mar 8, 2020 | 01:46 PM
sygibson's Avatar
sygibson
1st Gear
Just wanted to say "THANKS!!!!!!". My start/stop switch spring for my '08 Softail Springer CVO gave up the ghost. I was pissed to see HD only provides a $56 (though better than the expected "Hundred Dollars" minimum, right?) assembly replacement. Bumped in to this posting.
Found this posting. Went to Home Depot and picked up the 3/16" x 3" toggle bolt for $1.98 ... a little bit of patience and gentle bending to match the original ... and it worked perfectly. I couldn't get 2 of them to seat in there cleanly ... but now I have a spare ready to go if this one gives up.
HINT: SAVE YOUR ORIGINAL spring pieces. put them back together between two pieces of clear cellophane tape. You can use that as a template to bend your new springs to the same series of bends.
HINT: Try to determine the spring orientation inside the switch housing - BEFORE you take it out. So you can put the new one back in the same orientation.
Here's the exact part I picked up at my local Home Depot: https://www.homedepot.com/p/803732/204273387
bluelineman
Aug 15, 2016 12:16 PM
paul0311
Dec 7, 2013 02:30 PM
Fl Jimbo 05
May 26, 2013 10:51 AM
Freewheelin Franklin
General Topics/Tech Tips
Aug 19, 2012 04:11 PM
Spindrifter
Oct 30, 2010 06:59 PM
