Roll Forward on Start
Old May 27, 2013 | 06:45 PM
jake.h's Avatar
jake.h
Default Roll Forward on Start
Before heading off to the dealer, thought I would ask the pit crew about this. I did a search and didn't pull anything up here on hdforums. When I start the bike in gear, with the clutch pulled in, the bike still lurches forward. What is the deal? Will it get worse with time? Is it causing any risk of damage (other than rolling into - or off - something)? I would imagine it is some kind of clutch adjustment? Thanks in advance for the input.
Old May 27, 2013 | 06:49 PM
VTL nut's Avatar
VTL nut
Sounds like the clutch plates-discs aren't seperating-releasing.
Check your clutch adjustment.
Also it begs questions such as how many miles?
What lube in your primary?
Old May 27, 2013 | 06:50 PM
69cj's Avatar
69cj
It is just breaking loose the static tension in the oil in the clutch discs. You are putting unnecesary strain on your starter.
Old May 27, 2013 | 06:53 PM
jake.h's Avatar
jake.h
It has just about 3000 miles on it. Bought it in March, had the first service by HD a month or so ago. So I am thinking that HD needs to deal with it. Will a clutch adjustment fix the problem? Or is it bigger than that?
Old May 27, 2013 | 06:55 PM
louisianaSVT2001's Avatar
louisianaSVT2001
Why not start in neutral?
Old May 27, 2013 | 06:58 PM
69cj's Avatar
69cj
See post #3. Don't ask questions if your fishing for an answer that you like.
Old May 27, 2013 | 06:59 PM
hdbob2006's Avatar
hdbob2006
start it in neutral,at least till you get the clutch adjusted.
Old May 27, 2013 | 07:02 PM
Uncle Larry's Avatar
Uncle Larry
You should ALWAYS start it in neutral
Old May 27, 2013 | 07:03 PM
Groucho1's Avatar
Groucho1
If mine is a cold start it slightly moves forward...If it's hot doesn't do it again.
Old May 27, 2013 | 07:10 PM
jake.h's Avatar
jake.h
I think, respectfully, that your comment misses the point. I don't trust the dealer. - they probably charged me for a clutch adjustment that they never did (at 1000k) I want to be able to stride in and say, "Hey, adjust my damn clutch."
The response you are referring to, which reads: "It is just breaking loose the static tension in the oil in the clutch discs. You are putting unnecesary strain on your starter," doesn't answer the question as to whether a clutch adjustment is all that is needed.
