Help - Radio Interference
Old Oct 22, 2013 | 01:17 PM
Rlac1's Avatar
Rlac1
Not happy to hear Harley's response. I just bought a used 2010 Ultra Classic. All the lights are LED and the previous owner connected the tour pack lights to the blinker. If I use the radio, I get static with the blinker on only. Each time it blinks, it creates static. Does not happen with Ipod though. I would hate to disconnect this feature, since I like the way it looks and I think it is a great added safety feature. I may just leave it and live with it. As mentioned, only when blinker on, and safety is most important.
Thank you for providing this information. It was driving me crazy.
Old Oct 22, 2013 | 01:31 PM
rpking's Avatar
rpking
I get static too with my blinkers on (custom dynamics led's) I love the lights, very very bright.
I will keep them on no matter what, I'm going to start with the ground wires I hooked up when I installed the lights.
I have found that problems in electrical circuits especially lights it's often a bad ground giving me problems.
Old Oct 22, 2013 | 04:58 PM
1st 96 ultra's Avatar
1st 96 ultra
try some louder mufflers , or some dielectric grease on the plug
Old Oct 22, 2013 | 05:09 PM
kirbyblue's Avatar
kirbyblue
the noise in mine goes away when I engage the brakes. It's sounding more and more like that brake light/running light box thing
no noise on acc
I need to find that box
o the guy that found the y connector, that could be a small factory amp?
Old Oct 22, 2013 | 06:36 PM
UltraNutZ's Avatar
UltraNutZ
no noise on acc
its under the seat usually located right behind the battery on the fender.
Old Oct 22, 2013 | 06:43 PM
just plain john's Avatar
just plain john
^Yeah, that
Old Nov 15, 2013 | 07:00 PM
slapshot12's Avatar
slapshot12
Great info. I was testing out a headset tonight and had hissing in the rider right ear only. Nothing at all in the passenger headset. I found the y-connector for the extra brake lights and the hissing went away when I removed it. The y-connector is right behind the ECM on the very front of the rear fender under the seat. Guess I'll just leave it off since it only gives me 2 extra lights and I have the Tour Pak lights too.
Old Nov 25, 2013 | 06:49 PM
slapshot12's Avatar
slapshot12
Has anyone found a solution to this running light/turn signal wiring harness causing interference with the intercom? I have the HD y harness and stock turn signals.
Old Nov 25, 2013 | 07:12 PM
UltraNutZ's Avatar
UltraNutZ
you have a bad y harness. get the dealer to swap it out for you
Old Nov 26, 2013 | 11:24 AM
slapshot12's Avatar
slapshot12
Thanks...I'll give them a call. Hopefully they will warranty it. I have no idea how low ago it was bought, or which dealer it was bought from.
