Hand grip replacment
Old May 31, 2013 | 05:09 PM
Timpechos's Avatar
Timpechos
Default Hand grip replacment
I have heard about using a piece of cardboard on the front brake to prevent damage to the switch when you replace the hand grips. Where do you put the card board?
Old May 31, 2013 | 05:11 PM
Joe2010ultra's Avatar
Joe2010ultra
between the Brake lever and the micro switch. Pull on the lever and look inside you will see a micro switch. slide the cardboard in there.
Old May 31, 2013 | 05:38 PM
jjnoble's Avatar
jjnoble
squeeze the lever, you will see the crack open between the housing the cable is attached to and the lever itself. Put your finger in there and let go of the lever. If it hurts you found the right spot to put the cardboard.
Old May 31, 2013 | 06:17 PM
Timpechos's Avatar
Timpechos
Got it thanks
Old Jun 1, 2013 | 06:23 PM
hungry horse's Avatar
hungry horse
By all means, use the cardboard or you'll regret.......experience is a b**ch!
Old Jun 2, 2013 | 05:07 AM
1511's Avatar
1511
By all means, stick something in there. I just went through this and replacing the brake light switch is a PITA. Here is what it looks like when u break it and it takes next to nothing to break it.
Old Jun 2, 2013 | 05:28 AM
Ron750's Avatar
Ron750
Old Jun 2, 2013 | 09:28 AM
Punjabi Rider's Avatar
Punjabi Rider
To just change the hand grips you don't need to mess with the brake or clutch unless you are changing switch housings depend on the bike year TBW grip is real easy to change compare to cable throttle.If you are changing switch housing its doable but require whole lot patience or lot can go wrong and then bike ends up on a tow truck.
Old Jun 2, 2013 | 02:21 PM
Speleo's Avatar
Speleo
The thickness of a 10" zip tie or a tie wrap as some call it, is just right to slip in there.
alkrisma
Jan 22, 2017 08:32 AM
icepick
Sep 6, 2012 07:31 PM
Joanrava
Jan 10, 2011 08:31 PM
xmarine
Sep 16, 2007 03:48 AM
lowleveldriver
Jan 12, 2006 08:16 AM
