Single Left Side Brake Lines?
Old Jun 3, 2013 | 03:28 PM
Texas Killa's Avatar
Texas Killa
Default Single Left Side Brake Lines?
I am ready to do the conversion to the left side only caliper, but am trying to find out what brake cables, if any I need. I put on some braided ones when I did my apes and would like something to match. Do I just need the lower with some kind of plug for the right side, or 1 straight all the way from master cylinder?
Help a dummy out here...
08 SG, non ABS - going to 6 piston caliper and 13" rotor.
Old Jun 4, 2013 | 10:19 AM
mrfuji's Avatar
mrfuji
Default single
never done that set-up.but this is like softail.sporster.dyna .mrfuji
Old Jun 4, 2013 | 02:59 PM
pit1600's Avatar
pit1600
changing master cylinder for a 9/16 and one straight line will be better solution. I will do it as i decided which caliper...
Old Jun 5, 2013 | 10:41 AM
Texas Killa
Thank you for the response.
Hmmm, hadn't thought of doing that.
Guess I'll go looking again at parts.
Old Jun 5, 2013 | 11:26 AM
grbrown's Avatar
grbrown
With a single caliper you only need a single line. That makes for a very tidy installation and the easiest possible brake bleeding! Harley make two master cylinders, for single and twin calipers and the aftermarket brake makers (if you go that route) make their calipers to match up with those master cylinders.
Old Jun 5, 2013 | 11:30 AM
RANGER73's Avatar
RANGER73
You can go to any auto parts store and get a brass plug to install in the "T" fitting. Then just remove the right side brake line and what ever else you need to remove.
Old Jun 5, 2013 | 11:31 AM
SGFlash's Avatar
SGFlash
I bought the 9/16 off eBay and ran one line down. Had magnum lines from my apes so I just called them and ordered a single.
Old Jun 5, 2013 | 01:24 PM
Hogpro's Avatar
Hogpro
Former Sponsor
I'd get a single brake line as opposed to plugging the T. On your 08 non abs all you need is the brake line from the master cylinder to the left caliper. The 9/16" master cylinder is a good idea too. I'm going to be doing this on my 05 and am going to try with the stock 11/16" master cylinder first to see how that works. I'll keep you posted whenever I get around to it.
Old Jun 5, 2013 | 07:32 PM
phnxrider's Avatar
phnxrider
I did this mod on my bike and changed to 9/16 MC as that is what the instructions stated. I wouldn't expiriment with braking ability, just my .02
Old Jun 6, 2013 | 04:51 AM
RANGER73's Avatar
RANGER73
No experiment, He'll have more pressure, more sensitive, so there's a learning curve. How often do you slam on the front brake?
