I took these from a chart I had copied at the dealer. It was in a looseleaf type binder on a display stand. these are for sea level.
3000 rpm 45 hp 75 ftlb torque
3500 rpm 50 hp 73 ftlb torque
5300 rpm 65 hp 65 ftlb torque
These figures (tq hp) are estimate as the chart is not that refined.
in 5th gear between 3000 and 3500rpm you will be between 68 and 75 mph (approx)
5300 is the cross over where hp and tq are same.
Anybody know what the stock Dyno numbers would be on a 2006 TC88.
I would just like to compare.
The best I could share with you is my '06 Ultra with just the SE Air Cleaner, stock pipes, and HD flash for this "almost stock" configuration. Took the "almost stock" bike to a dyno tuner to have a PC III installed --- just to see what the PC III would do for a stock bike.
The results were:
- "Almost" Stock - 69.15 HP, 70.30 TQ
-PC III and tune - 72.04 HP, 74.95 TQ
Hope this helps answer your question. By the way, based on what I learned, I would do a PC III (or SERT) and dyno tune on any EFI bike --- even a stone stock bike. I could really feel the difference in the before and after performance.
