I read several thread in the audio section, which describe how much better speakers sound wrapped.
I'm going to wrap the batwing speakers, but I can find any info on wrapping the lower speakers or the tour pack speakers. Will it help since they are already in a small enclosure?
My stereo is super loud (2 amps) and sounds clear, but for 5 bucks it's worth taking it apart if it will make it even better.
Does anyone have experience wrapping all their speakers?
It's 110 degrees here this week - too hot to ride.
You guys up north are so lucky!!! It's only been a couple weeks since the heat rolled in and I'm already feeling the itch.
I just wrapped my fairing speakers two days ago, what a difference. I don't have the lower speakers but with the arc audio mpak 6 it made the bass from the 6.5s a lot more pronounced. figured I would put my 2 cents in on the wrap. btw make sure you wrap it well, one wrap around wont do anything mine looked like big *** cotton ***** when I was done.
On My Ultra I wrapped the ones in the bat wing also some dyna mat. I put some pollyfill in the lower woofers and also the rear pods. The sound improved. I have 2 amps in the fairing and was carefull I didn't come in contact with the amps. What I like the most is the vibrations decreased.
I did my pod's as well. Just took the speaker out crammed some in and put it back together. Don't be stingy. Sounds better to me and it was cheap enough to do.
Good advice. I will be mindful to keep it away from the amps.
Cool. I'm convinced and headed out to the garage to pull it apart.
