Ultra limited cam install????
Old Jun 21, 2013 | 08:10 AM
  #51
lhgdale's Avatar
lhgdale
Just to give an update, got the cams installed. I started on Wednesday and wrapped everything up Thursday morning. The install went flawlessly. I didn't even need a spacer for the sprocket alignment. I measured about ten times using 2 different straight edges and it was in spec.
The bike runs great! It really is amazing how much a difference a set of cams make in these motors. The motor just feels HAPPY HAPPY HAPPY.
Thanks for all the help!!!!!!!
Here is a video of the first start up after install.
http://s43.photobucket.com/user/lhgd...dfd7a.mp4.html
Old Jun 21, 2013 | 09:57 AM
  #52
stro1965's Avatar
stro1965
Way to go! Did you happen to check crank run-out while you were in there? The ONLY thing I don't like about my cam swap is the exhaust reversion noise I now get through the intake. But I couldn't be happier with the power increase. My little 96" walked away, I mean ran away, from a stock 103" Road Glide when we rolled on the throttle in 5th gear. Wasn't even close!
Old Jun 21, 2013 | 02:09 PM
  #53
lhgdale's Avatar
lhgdale
Is that what that noise is?? The push rods really quieted up the valve train noise except now instead of the high pitch ticking I get a low bass ticking when the engine is under load or at a low rpm. It seems to stop once the bike is at cruising rpm. I called Fuel Moto and they said this is normal. They also said it was coming out of the intake. I'm not sure if it's coming from the push rods or the cams?
Old Jun 21, 2013 | 02:44 PM
  #54
Bill03E's Avatar
Bill03E
Originally Posted by the warden
If you are replacing with chain driven cams and not gear driven, then you need not worry about crank runout. Ask yourself this question. What am I going to do if I don't like the amount of runout? Nothing, unless you are prepared to tear down your motor, true and weld the crank and put it back together. Costly, time consuming, and unnecessary if all you are doing are chain driven cams and not a triple digit HP and TQ screamer.
Well you are partially right, but if that run out is very high, then it will beat oil pumps to death, and probably crank bearings.
I would say that magic number is around 8 thousandths.
Old Jun 21, 2013 | 05:14 PM
  #55
stro1965's Avatar
stro1965
Yeah, you're probably hearing reversion. It was obvious on mine when I pulled the football air cleaner cover and it was MUCH louder.
Old Jun 21, 2013 | 05:16 PM
  #56
stro1965's Avatar
stro1965
That can't be! HD says 10 thousandths is within spec! LOL, mine measured almost 7 thousandths!
Old Jun 21, 2013 | 06:50 PM
  #57
lhgdale's Avatar
lhgdale
I have an open air cleaner so I'm sure it's louder on mine. Is that what you hear a deeper tick? Like I said mine is louder under load.
Old Jun 21, 2013 | 06:52 PM
  #58
Recycled's Avatar
Recycled
Originally Posted by Strait
Not trying to step on toes or anything I'm really just curious to understand this how can you get the crank 180 degrees off when the sprocket that goes over the end of the crank is keyed I will only go on in one place? Correct?
The oil pump fits over flats on both sides of the crankshaft and it is possible to mount the moving portion of the oil pump 180 degrees off from its original orientation if the rotating assembly has been rotated while the oil pump was removed. This is what was meant, no one said the timing would be off 180. Take a look at a parts diagram to see how the pieces fit together.
Old Jun 21, 2013 | 07:05 PM
  #59
stro1965's Avatar
stro1965
Mine sounds almost like a knock, but not metallic. Noticeable on my bike only under load, particularly when 2 up.
Old Jun 21, 2013 | 07:28 PM
  #60
12hdrk's Avatar
12hdrk
Nice job! I will be doing the same over the Winter.
