Shifter linkage issue
Old Jun 9, 2013 | 10:32 AM
mikebaby's Avatar
mikebaby
Default Shifter linkage issue
I replaced my shifter linkage with an aftermarket one. The new one is a bit longer than stock. Now it does not feel like its shifting as well, and I have no click feeling when gears change (and sometimes they don't). 1st gear is also harder to engage. Nothing is binding. Does the front shifter arm being lower and a bit more forward cause this? I'm about to swap it back to stock.
Thanks,
mikebaby
Old Jun 9, 2013 | 10:40 AM
Leftcoaster's Avatar
Leftcoaster
Easy-peezy....move your shift lever up one or two splines on the shift shaft.
Most linkages are adjustable at the ends also. They can either be lengthened or shortened to suit your preference. Heim joints on the ends are the way to go.
Old Jun 9, 2013 | 10:42 AM
Bill03E's Avatar
Bill03E
Is the new linkage not adjustable? If your front lever is far forward, it will make changing gears harder, ideally you want both levers straight up,and down.
Old Jun 9, 2013 | 10:48 AM
mikebaby's Avatar
mikebaby
It is adjustable and does have heim joints, but the entire piece is longer and the arm connecting it to the tranny shift arm is physically longer so the front arm is angled further forward a bit.
Leftcoaster: I did adjust the shifter peg arm.
Thanks,
mikebaby
Old Jun 9, 2013 | 11:03 AM
Leftcoaster
No pics makes it a bit of a challenge, but if it is a simple rod (like the stock unit) you can shorten it and re-thread for the Heim.
If it's one of those fancy machined units you may have the wrong piece for your model of bike. If that's the case, contact the manufacturer to be sure of the correct fitment.
Good luck, man.
Old Jun 9, 2013 | 07:08 PM
mikebaby's Avatar
mikebaby
Here is a photo.
Thanks,
mikebaby
Old Jun 9, 2013 | 08:27 PM
05UltraBob's Avatar
05UltraBob
That does look a bit too long. The front inner shift arm should be straight up and down. It must be for a different model, perhaps a Heritage Classic. I believe those are a bit further forward so they need to be longer.
Old Jun 9, 2013 | 08:29 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Bolt to bolt that should measure 12" centered
Old Apr 29, 2018 | 04:18 PM
Joe741's Avatar
Joe741
I have a similar question:
I'm about to replace the stock linkage on my 2001 Fatboy with an aftermarket part.
I notice that to remove the stock linkage, the front connection is pretty straight forward, but I checked the Parts book, and to disconnect the rear, it looks like the connector on the shifter rod has a threaded stud built into it that screws into the rear shift arm?
is that true?
Any ideas on a easy way to get that rear bolt out? Maybe have to take out the voltage regulator to get to it?
Old Apr 29, 2018 | 07:40 PM
dawg's Avatar
dawg
is that true?
Simple once you see/do it. Take a wrench and turn it, it’s threaded into the rear arm.
