strange sound in turns
Old Jun 10, 2013 | 07:59 PM
gbear's Avatar
gbear
Default strange sound in turns
I have noticed when I go in to a left hand turn a whirring noise coming from the rear of the bike. it is a constant steady sound in the turns until the bike comes back up to center. It does not make this sound when riding straight and in a right hand turn I hear it but not as loud. I had the radio turned off talking to my lovely bride and noticed it when I was going through some sweeping turns. could it be the tire tread. As always thanks for your honest input.
Old Jun 10, 2013 | 08:09 PM
HEEP's Avatar
HEEP
Had the same problem on mine. Had the rear bearing replaced. Of course the dealer said they werent bad and that my rear tire needed air and had a bad wear pattern. However, they did change out the bearings, and the sound went away.
HEEP
Old Jun 10, 2013 | 08:12 PM
bgdv1's Avatar
bgdv1
yep, look at your tires chance are there feathered. my SG tires were like that and basically howled in corners,
Old Jun 10, 2013 | 08:14 PM
BigDawgQC's Avatar
BigDawgQC
Rear tire.
Old Jun 10, 2013 | 09:06 PM
wurk_truk's Avatar
wurk_truk
I agree it is most likely rear tire. Been there, had that happen, too.
One thing I have found is try to keep the chicken stripe as wide as possible. That wears the tires more even.
Old Jun 10, 2013 | 09:10 PM
rufasim's Avatar
rufasim
What do you mean they are feathered? Needs replaceing immediatly? I just noticed that my tire does the same but only has about 11,000 miles. Plenty of meat still befor the wear bars. I guess I will have to take a closer look at them tomorrow.
wndchsr2's Avatar
wndchsr2
Cupped tires will make that sound.
Old Jun 10, 2013 | 09:11 PM
hyperfocal's Avatar
hyperfocal
It's my 3rd rear tire. When it's time to replace, (Dunlop) does it everytime. No biggy, just time for a new one.
Hyper
Old Jun 10, 2013 | 09:14 PM
hyperfocal's Avatar
hyperfocal
That's true, may be under warranty. I said maybe. Check with dealer.
Hyper
Old Jun 10, 2013 | 09:15 PM
ftworthcowboy's Avatar
ftworthcowboy
