I bought a set as the other vendor's site was down and it was not disappointing. The bolts and spacers were good quality and nicely powder coated and installed with out an issue. Instructions were fine.
They were only $40 shipped which I felt was great. I can tell its a small operation from the packaging as it was simple but effective but I like supporting local and small business' when possible.
My only advice would be an option for chrome bolts but the caps for the bolts were a nice touch.
I recommend them if you need a set and the 1" set makes a noticeably more comfortable foot position, especially on the right getting your boot away from the pipe.
When you use those 1" extenders with the extended HD Floorboard Pans the difference is quite dramatic. 1" out and 1" forward makes a lot of difference. I bought the other manufacturers extenders but the kit looks identical. I think chrome bolts would easily double the price though.
Had the first real ride with today with them on the way to work. Really noticeable, wide and comfortable. I notice my whole foot for the most part is now on the rubber pad and gives a soft feeling to the floor board now which feels different.
Slight down side is you can hit your lower front leg on them with your feet down so you may feel a slightly restricted foot movement between the driver floor boad and passenger foot board but this will be with any spreader.
