Hardbag Flew Off at 60 MPH
Old Jun 15, 2013 | 04:32 PM
casique's Avatar
casique
Default Hardbag Flew Off at 60 MPH
Check those Brukus bolts! My bag flew off at 60 MPH and skidded for a while. The other was nice and tight, go figure!
Most of the damage was on the lid and bottom of bag. It's going to need light body work and paint.
Can the new ABS bags be fixed paint/body work?
Thanks.
Old Jun 15, 2013 | 04:49 PM
jus2anoyu's Avatar
jus2anoyu
That's not very reassuring for the brukus kit...
Old Jun 15, 2013 | 04:52 PM
hog95023's Avatar
hog95023
Thanks.
Yes they can be Fixed easily by a competent body shop. Check with your local HD and see who does their repair work. Those guys do lots of insurance jobs and should e well practiced
Old Jun 15, 2013 | 05:08 PM
Gunnysgt's Avatar
Gunnysgt
No thanks on those bolts. Never had a properly secured saddlebag fall off with OEM fasteners in 27 years of Harleys. I'll stick with them thanks.
Old Jun 15, 2013 | 05:38 PM
V2Evo96's Avatar
V2Evo96
casique sorry to hear that happened to you. I nearly lost one before I got the Brukus kit.
The Brukus instructions say to tighten the fastener until the lock washer is just compressed flat.
Not suggesting that you didn't do that, but any fastener can back itself off with none or minimal lock washer tension.
Old Jun 15, 2013 | 06:01 PM
hardheaded's Avatar
hardheaded
that's why i run a longer bolt with a nylock nut on the outside.
Old Jun 15, 2013 | 06:15 PM
casique's Avatar
casique
Anything is possible. I could have screwed things up. I had the Brukus kit for two years with no issues. Definitely NOT blaming Brukus. It's my fault for not checking fasteners more often.
Old Jun 15, 2013 | 06:29 PM
TUCCI's Avatar
TUCCI
you haven't had the bag off in two years you say, do you open them up very often...I'm not criticizing by any means but for those bolts to back out it would have to be very obvious whenever your in the bag. Could there be another reason the kit failed?
Old Jun 15, 2013 | 06:31 PM
Arizona's Avatar
Arizona
Sorry to hear about your bag. Things happen I guess. Maybe a little blue Loctite on the threads would help if you don't take your bags on and off a lot.
This isn't something I've heard about with the Brukus bolts, so they may have just backed out on you over time if you didn't tighten them quite right. You do hear of the bags having this happen far more often from the OEM fastener - due to improper installation when put in.
However the risk you take is BOTH bags flying off - into the trunk of a dirtbag's car when you're parked at the mall, if you run with the OEM fasteners.
Let us know how the repair goes...
Old Jun 15, 2013 | 06:33 PM
smitty901's Avatar
smitty901
This one comes around again.
I'll stick with the stock pins 43 years never had one come off or stolen, never seen one come off and they hold pretty good. Totaled the bike destroyed the bags but the pins held just fine, both still in place.
