Just installed True Track
Old Jun 24, 2013 | 07:27 PM
FL-kruzen's Avatar
FL-kruzen
Default Just installed True Track
I never had the wobbles but I had a good deal on the progressive True Track. It's been sitting around for months so I just installed it. I really don,t see how it would help with wobbles or traction or anything for that matter. It attaches to the right side where the passenger foot peg mounts and then to the bottom of the transmission. Perhaps it keeps the engine from twisting, who knows. I haven't rode it yet because I need to replace my oil sending unit while I have access. Has anyone installed one of these and what difference can you tell?
Old Jun 24, 2013 | 09:41 PM
btsom's Avatar
btsom
Ooops
Old Jun 24, 2013 | 09:46 PM
btsom's Avatar
btsom
I have the Progressive unit on an 08 Road King. The theory of wobble is that side loads on the rear wheel (On a gyroscope, the force expresses itself 90 degrees of rotation from the point the force was applied) cause some rear wheel steering input. That is why when rolling a free wheel, once it banks in one direction, i begins to turn in that direction. The side load at the bottom exerts a turning force 90 degrees of rotation later making the wheel turn. The same thing happens with your rear wheel (all spinning wheels, actually) and the turning force at the back of the wheel applies turning force to the rubber bushings which hold the swing arm causing some rear wheel steer. If you look at any of the stabilizers, they prevent any left-right movement of the front of the wheel (and swing arm). My machine had a noticeable tendency to tighten and widen high speed turns independently of any input from me. This had me always correcting from turning too tightly to turning too wide and back again in all the high speed sweeping turns. I could never find a "sweet spot" of proper turn radius to just run through the turn, I was always hunting for just the right turn radius. The Progressive link has eliminated that hunting, I can establish a turn and just ride smoothly through it now. Hope it does the same job for you.
Old Jun 24, 2013 | 11:21 PM
Ryder7140's Avatar
Ryder7140
I have an 01 ultra. Have new (stock) swing arm bushings. I have also replaced the top and bottom links. Then aligned the wheels using a 8' florescent light bulb. Mine still feel funny in a big sweeping curve. Kind of like btsom described. The rear wheel feels like it is trying to steer out on its own. I have thought about trying the true track. But for now I just go slow in the curves.
Hope you have good luck with it.
Old Jun 24, 2013 | 11:34 PM
CSS_FXD's Avatar
CSS_FXD
just buy a 2009 and up and be done with this. I have never had any issues myself either but once i do I will say so long to my 2006 hello 2009 or newer and be done with it. Beet of luck to all with the wobble.
Old Jun 25, 2013 | 05:42 AM
Black Gator's Avatar
Black Gator
Have had the True-Trac on my 2012 Street Glide almost since new. Since this was my first Touring bike I asked my buddy to do a comparison ride. At the time he was riding a 2007 SE Electra Glide. I thought his observations were interesting since he's owned 13 new H-D of all types since the early 70's. his observation was that the Street Glide handling was crisp and sure. In the year+ since being installed I've had numerous opportunities to push the bike hard through some very interesting "twisties". The bike has always responded with very stable handling. On several occasions recently while out with a few others I was motioned to the lead on some challenging road sections so as not to be held up. Oh, the bike that sent me ahead....a 2013 BMW K1600 GT.
I'll stick with my True-Trac, thanks.
Old Jun 25, 2013 | 05:55 AM
Bodean46's Avatar
Bodean46
Installed an AlloyArt stabilizer on my 01 Ultra 3 years ago. Still rides like it's on a rail now.
Old Jun 25, 2013 | 06:01 AM
tbone108's Avatar
tbone108
It's on my list of things to do but not sure if there is a uk stockist ?
Old Jun 25, 2013 | 08:45 AM
RaceFace's Avatar
RaceFace
You need to check out grbrown's thread on wobble. It's very informative and aims you at a solution, which is the True Track.
https://www.hdforums.com/forum/touri...e-exposed.html
I had the wobble happen to me with my girlfriend on the back. I had recovery room and was able to pull out of it. Scared the hell out of me and at the time, I didn't know anything about "death wobble", I just figured it was a heavy bike and that's what they do. Wrong. I know about it now and have since put the True Track on the bike. It runs on rails now and from what I've read, the newer frame design didn't eliminate the issue, its just less prevalent, but it still happens.
Old Jun 25, 2013 | 09:37 AM
Hogpro's Avatar
Hogpro
Former Sponsor
The funny thing is if you got the Progressive version that is not a True Track. True Track was the first company to make this type of a stabilizer and every fone else copied them. Their stuff costs a little more as I have been looking for one for my bike but am still undecided on which to get. I will probably get Tru Track as I have it on my Dyna and they are local so I can pick it up in person.
Here is a link to Tru Track.
http://www.true-track.com/
Here is a link to the Progressive product.
http://www.progressivesuspension.com...ink/index.html
There are a few other companies that make these things now too. I think Alloy Art, and others. Another thing to look in to is the Stabo-Bo swing arm bushings.
I am yet to experience the high speed wobble, but I'd rather never have to. When I put one of these on i will report back after with my thoughts but judging from the difference it made on my Dyna I am sure it will be quite noticeable.
