Bike shut off while riding!
Old Feb 10, 2014 | 12:17 PM
  #31
bgtyma's Avatar
bgtyma
Stage II
I have an 01 and the same issue I just replaced the circuit breaker and still doing the same thing what is the process for making the change you made I would like to try and do the same
Old Feb 10, 2014 | 12:28 PM
  #32
casique's Avatar
casique
Check the battery cables, make sure they are clean and tight.
Old Feb 10, 2014 | 09:46 PM
  #33
rcreechssr's Avatar
rcreechssr
Originally Posted by Deckman
Happened to me on one of my earlier bikes and it was a loose lead on the negative pole of the battery.
Ditto here. Wrong bolt in battery terminal allowing terminal to lose contact intermittently.
Old Feb 10, 2014 | 09:59 PM
  #34
mkguitar's Avatar
mkguitar
Early Twin Cam models had a recall for the tip over switch bracket breaking and the tip over triggering on turns.
in board of the rt side cover electronics.
mike
Old Feb 10, 2014 | 11:45 PM
  #35
Def Mute's Avatar
Def Mute
The terminals inside the ignitions switch can also become pitted and lose contact. Happened to mine. I disassembled the switch, cleaned the contacts, and actually moved the one from Accessory side over to Ignition side because it was burned so badly. Haven't had a problem since I did that 3 years ago...
Most people would have purchased a $25 replacement Ignition switch, but I'm a cheap ***!
Old Feb 10, 2014 | 11:52 PM
  #36
Freesince1903's Avatar
Freesince1903
this also happened on my 2011 streetglide would shut off at weird times. turned out it was the ign switch.
Old Feb 11, 2014 | 05:26 AM
  #37
sunderhill's Avatar
sunderhill
Check for recalls here.
https://www.harley-davidson.com/en_U...e-recalls.html
Old Feb 11, 2014 | 06:46 AM
  #38
timbo141's Avatar
timbo141
02 and 03 bikes could have the wiring harness short out on the frame. It is a three piece harness, I don't remember which one or where. Do a search on here
Old Feb 11, 2014 | 09:41 AM
  #39
stan60's Avatar
stan60
It could be any of these issues, but probably the most common is a loose negative ground on the battery.
Old Feb 11, 2014 | 10:06 AM
  #40
caberto's Avatar
caberto
This happened to my wife's 06 Sportster 1200, ended up being a cracked/broken wire near the seat. Indy said it had a pretty tight loop tight under there and the wire was bent too sharply, eventually cracking. He replaced the wire, eased the entire loop a bit, and all has been good for about two years now.
