Spring preload question
Old Jul 7, 2013 | 04:30 PM
rhuff's Avatar
rhuff
Default Spring preload question
Okay, trying to set up my ohlins shocks for a solo trip....
Increasing the spring preload increases ride height, does this mean that if I'm adding more weight, I'd need to increase the preload from where I currently have it?
If I increase the spring preload, is the collar getting closer to the top of the shock (lengthening the spring)....I feel stupid right now.....
Old Jul 7, 2013 | 04:48 PM
HDV-GLIDE's Avatar
HDV-GLIDE
To increase the pre-load, you turn the adjusting nut clockwise to stiffen the spring (making it shorter). That's what I did with my Ohlins and JRI Shocks. I was in the same boat you are, until I spoke with Howard and also bought a huge caliber at Harbor Freight. Once you know what your pre-load is supposed to be, set the caliber to that measurement and use the middle of both shock bolts as the reference mark.
Old Jul 7, 2013 | 09:54 PM
goofey's Avatar
goofey
I don't want to crash this thread but would like to know if more preload will keep the bike from bottoming out?
Old Jul 7, 2013 | 10:15 PM
tencrore's Avatar
tencrore
I'm going through the same adjustments as you are! Yes, it's my understanding that more pre-load does keep the bike from bottoming out. Using the "zip-tie" method, I've gotten it to about 3/8" above the bottom rubber cone. This is without the tour pack and saddle bags. Tomorrow I'll put on the TP and see where it's at and wrench the collar about 1/2 turn more to accommodate for the saddle bags. After that, it's on to adjusting the damper to smooth the ride out a bit more.
Best of luck!
Old Jul 7, 2013 | 10:20 PM
Lowcountry Joe's Avatar
Lowcountry Joe
You adjust the preload the same way you did the first time. Remember? You adjust it so that your rider sag is about 1/3 of the total travel of the Ohlins piston.
My #6 Ohlins have around 93 mm of travel. You want to adjust the preload on the shocks as a function of the fully extended shock (with rear wheel off the ground) versus you and all your gear on the bike with the rear wheel on the ground. So you want to measure from center to center of the mounting bolts with the rear wheel off the ground, then take another measurement with the rear wheel on the ground with you and all your trip weight firmly on the bike (this is called rider sag). You want to adjust the preload to where the difference between these two measurements is about 31 mm, or 1/3 of the total travel of the shock piston. My wife helped me with the measurements, because it's pretty difficult to do it yourself with any degree of accuracy. Not saying it can't be done alone, but another person measuring makes for more accurate measurements and much less time spent in the process.
This is all from memory so I hope I have not screwed up this procedure for you but if I have, I am sure Howard will come in and straighten me out.
And don't feel stupid, no reason to feel that way because you are not stupid. You own Ohlins don't you?
Old Jul 7, 2013 | 10:23 PM
Rich67's Avatar
Rich67
Glad this was brought up, I gotta mess with mine to , I've lost bout 50 lbs. bout 2 weeks goin on a 14 day trip thinking by the time I get er loaded up with the wife's stuff in the rack bag and tools I might be where I need to be tell I get back, but I haven't checked them since I put them on last summer.
Old Jul 8, 2013 | 12:18 AM
rhuff's Avatar
rhuff
Default fffff
Yes, I have the ohlins. His 2 1/2 with 93 mm of travel. I measured the shock from the top and bottom of the bolts vs the center as I figured it'd be more accurate. I have it set up right now at about 29 mm. Feels about right loaded down.
Old Jul 8, 2013 | 04:02 AM
goofey's Avatar
goofey
If you ride 2 up most of the time should I have the wife on back when I check the rider sag. I want to thank ruff for starting this thread. The info is helping me hope it is helping him.
Tucker99
Dec 25, 2017 10:42 PM
PFWiz
May 22, 2017 08:27 PM
durtyhairy
Sep 18, 2016 02:29 PM
SpecialEd
Feb 6, 2015 11:19 PM
ryanjames170
Sep 24, 2013 12:41 PM
