Someone posted about a week about about LED turn signals not being plug-n-play, well for him and others looking to install them, here's a video that shows how it's done...
From: Western Illinois, land of bad roads, and corrupt politicians
I installed the LED front and rear Turn signals, just did the fronts today. Darn near a plug a play for my bike, just had to remove the spot wires from the plug as well. Piece of cake install for the front. The rear took a bit more since two of the wires are re routed to plug in hole number 4 of the plug. Did the tail light as well. Pretty simple install except getting to two of the allen bolts on the front and rear, they are a PITA. Made a special short allen just for that
If your referring to the load equalizer, I used the Biketronic one, unplugged the connector on the bike, plugged the equalizer into one end, plugged the wiring from the equalizer into the other end of the stock connector and done....Maybe some other equalizers involve more work but my set up on an 09 was all plug-n-play....
Looks easy enough, might have to get these myself.
Did you disconnect the battery to install the biketronics load equalizer.
