Burst Headlight Trim Ring/ Anyone else install?
Old Jul 18, 2013 | 07:18 PM
SOCALHD's Avatar
SOCALHD
Default Burst Headlight Trim Ring/ Anyone else install?
Last night I installed the New Daymaker LED lights and went with the new Burst Collection Trim ring. Unlike the other Harley Trim Rings the instructions say to remove OE trim ring. The Burst trim ring has a very small lip that is supposed to slip between the bezel and fairing. After a couple tries I got it to sit right and it seems secure. Just a bit worried it migh fall off as it is only depending on that small lip and bottom clamp screw to hold it in place. Curious if anyone else has encountered this
Old Jul 18, 2013 | 10:01 PM
z edge's Avatar
z edge
I have the Burst trim ring with the stock headlight. Been on for a couple months with no problems. If you can't pull it off by hand, it should be secure.
Old Oct 21, 2013 | 01:57 PM
1sweetglide08's Avatar
1sweetglide08
I installed one a few weeks ago and guess what? It fell off...I thought I had it screwed on tight. I guess I should have used blue loctite.
Old Oct 22, 2013 | 12:14 AM
speedracer's Avatar
speedracer
I've had one on for 500 miles and so far no problems.
Attached Thumbnails Burst Headlight Trim Ring/ Anyone else install?-img_4218.jpg
YodaddyKeith
Oct 23, 2019 02:55 PM
bman7163
2014-2024 Touring Models
Feb 17, 2018 09:10 AM
twp98
Apr 3, 2016 06:00 AM
foxtrapper
Nov 21, 2013 12:44 PM
SoonerSoftail
Feb 24, 2011 08:18 AM
