fender script new / old styles
Old Jul 20, 2013 | 07:54 PM
Mitchbb61's Avatar
Mitchbb61
Stage IV
Default fender script new / old styles
ok guys, need a little help. When I bought my Road King it had an aftermarket fender on it. I was lucky enough to find an OEM same color used fender in great shape. All of the factory holes were drilled and I thought I was good to go. I ordered all of the trim pieces, but when they showed up I found that the script does not line up in the holes. I have attached a couple of pictures from what I have found. anyone know where to go with this? I need to know where to find the script with the pins equal distance apart from one another.
Attached Thumbnails fender script  new / old styles-newscript.jpg   fender script  new / old styles-img_20130524_141641_107.jpg
Old Jul 20, 2013 | 08:25 PM
mkguitar's Avatar
mkguitar
so in the pic on the left, that part was introduced in 1994 ( the -94 suffix).
what year bike is your fender from?
I just went through the online parts manual and the 1994 RK script is used right up through 2011 models...
mike
Old Jul 20, 2013 | 08:30 PM
Mitchbb61's Avatar
Mitchbb61
Stage IV
Fender was supposedly from a 2006. Same year as my bike.
Old Jul 20, 2013 | 08:37 PM
hdbob2006's Avatar
hdbob2006
Shave the pins off with a small grinder or dremel tool,and attach them with 3M double sided trim tape.
Old Jul 20, 2013 | 09:00 PM
B4Wheeler's Avatar
B4Wheeler
Which two outer pins match yours and just remove the inner pin.........
Old Jul 20, 2013 | 09:06 PM
iglideUC's Avatar
iglideUC
+1 for the double stick tape
Old Aug 2, 2013 | 06:59 AM
Mitchbb61's Avatar
Mitchbb61
Stage IV
No "two" pins match up. Too intricate for double sided tape. Thinking of a formed backing plate. not sure yet.
Old Aug 2, 2013 | 07:30 AM
valvestem's Avatar
valvestem
I tried the 3M tape on an Electraglide fender emblem, but it is too thick. And like the OP said, the emblem is too intricate. I ended up taking the emblem to a sign shop, and they cut out vinyl ones for me for $14.
Old Aug 2, 2013 | 08:41 AM
CBud's Avatar
CBud
I used blue painters tape to make a template on the fender, lined up the pins,marked with a pen on the tape and drilled new holes. BUT I was working from a blank. Will the script hide the original holes?
swhoelefp69
Aug 22, 2018 05:20 PM
ocsoswat
Sep 16, 2016 04:21 PM
1st 96 ultra
Mar 1, 2015 06:40 PM
pflatout
Oct 18, 2013 05:27 PM
Hotrodz_n_Harleyz
Jan 24, 2013 01:18 PM
