Speed Bleeders
Old Jul 21, 2013 | 11:33 AM
kdodd's Avatar
kdodd
Default Speed Bleeders
Bought a set of speed bleeders for my 03 FLHTI, pretty straight forward change over. Bleed the brakes as directed, but they still fill a bit spongey. Any body had this problem, maybe a fix? New to doing my own maintenance so bear with me.
Old Jul 21, 2013 | 11:52 AM
MAJOR's Avatar
MAJOR
If they feel spongy you prob have air in the line. Try again. Vacuum pump or the old fashioned method of inserting a tube into a reservoir of fluid and pumping seems to work for me. Careful not to get fluid on your paint.
Old Jul 21, 2013 | 12:41 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Might need to flush out the old & put in some new recommend every 2 yrs.
Old Jul 21, 2013 | 12:55 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Just keep running new brake fluid through the lines. The air will eventually work its way out. Doesn't hurt to tap on the lines a little from time to time. Keep all your painted surfaces covered. Don't let the reservoirs run out of fluid during your process. Take your time.
beanoboy
Mar 4, 2017 11:41 AM
dochawken
Jun 22, 2014 07:06 PM
The Nev
Oct 28, 2009 03:38 PM
casique
Apr 26, 2009 10:01 AM
hdpearson13
Apr 19, 2008 04:08 PM
