can you reverse bleed a speed bleeder??
Old Jun 22, 2014 | 01:43 PM
dochawken's Avatar
dochawken
Default can you reverse bleed a speed bleeder??
Replaced a brake line...just could not get the fluid to the caliper with the speed bldr.
Old Jun 22, 2014 | 01:48 PM
mkguitar's Avatar
mkguitar
I often use a syringe to push fluid from the caliper up to the master cylinder.
but 1st I drain some fluid from the lines. the fluid nearest the caliper is dirtiest
mike
dirtdobber's Avatar
dirtdobber
There is air trapped. Loosen the banjo fittings one at a time and bleed. Air can get trapped at these fittings. That is why I use a vacuum bleeder, pump.
Are you speaking of a speed bleeder, fitting?
Old Jun 22, 2014 | 02:01 PM
dochawken's Avatar
dochawken
I just took a large syringe and sucked the fluid thru the master to the caliper....once I got it started it cleared nicely...thanks fellas..
Old Jun 22, 2014 | 07:06 PM
dochawken's Avatar
dochawken
I took a zip tie and closed the brake lever and open the orifice.then took my syringe and applied suction..once the fluid started running at the caliper I removed the zip tie and bled in traditional manner....no worries!
thatctguy
EVO
24
May 24, 2021 04:57 PM
Pgh-mike
EVO
Jun 1, 2016 06:38 AM
Bowhunter61
Mar 9, 2013 05:52 PM
KDagostino
Wheels/Tires
Feb 15, 2013 08:31 AM
olliecox
Jul 6, 2006 12:33 PM
