Headlight issue
Old Jul 25, 2013 | 11:51 PM
Bugspit's Avatar
Bugspit
Default Headlight issue
Tonight I noticed my headlight was out but the hi beams work. Normally I would think it is simply a bulb out but last week I was jiggling wires around when I installed my scorpio anti theft. Could it be a wire that only affects low beams or is it a headlight that needs replacing?
2010 SG with 25k miles.
Old Jul 25, 2013 | 11:55 PM
mkguitar's Avatar
mkguitar
It could be either... get a spare bulb.
many of us buy our bulbs at the auto parts store...in a 2- pak.
that way you'll have a spare in the garage or saddlebag.
when you open up the fairing, throw a spare bulb in, if it works..then jiggle the wiring some...if it still works then there is the answer.
some States allow high beam in daytime- this will equalize the wear on the 2 filaments.
Mike
Old Jul 26, 2013 | 09:14 AM
journeyman's Avatar
journeyman
There are 2 separate filaments, one does not affect the other.
Old Jul 26, 2013 | 11:00 AM
Bugspit's Avatar
Bugspit
Thank guys,
Journeyman, two separate filaments yes, but would the wiring be two separate wires to the bulb. I guess my question is, since its just low beams out but high work, does that rule out a wire connection that I might have jiggled loose when I installed the security system. If its a bulb I can easily go get and replace.
Thanks again.
Old Jul 26, 2013 | 11:15 AM
mkguitar's Avatar
mkguitar
...either way you are opening the fairing up- see my previous response
( the lamp is most easily replaced by opening the fairing, rather than taking off the trim ring and removing the bucket)
oh and do NOT touch the bulb with your bare hands- it must be clean, use a paper towel or clean cloth to handle any bulbs
mike
Old Jul 26, 2013 | 11:43 AM
journeyman's Avatar
journeyman
There is a 3 wire connector to the bulb.
One is ground, one is low, the other high. Each independant of each other. The low is always the first to go. Nice to know you have the high beam as a back up, especially when moving.
When you pull the bulb and look you will know if it's bad. Probably is. As MK says , fairing has to come off.
Originally Posted by Bugspit
Thank guys,
Thanks again.
Old Jul 26, 2013 | 12:42 PM
FLHX-SRQ's Avatar
FLHX-SRQ
6th Gear
I would try the bulb first, much easier than opening the fairing to check wiring to find out it was just a bulb and there was no need to open the fairing.
Old Jul 26, 2013 | 01:13 PM
journeyman's Avatar
journeyman
Even easier to have your neighbor check his bulb... but eventually you'll need to take the fairing off to check yours.
Old Jul 26, 2013 | 01:39 PM
FLHX-SRQ's Avatar
FLHX-SRQ
6th Gear
Not sure what your getting at? There is no need to take the fairing apart to get to the headlight bulb on a Street Glide.
Old Jul 26, 2013 | 02:10 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Yep, trim ring comes off with one screw, headlight comes out with a few screws, pull the plug and it's sitting in your lap. The wires are easily accessible with the headlight out also...
