headlite rewire???
Old Mar 1, 2007 | 10:45 PM
relli's Avatar
relli
Default headlite rewire???
im used to running a headlite modulator on hi beamwith a lightbar. but my harley has the lite bar wired to lo beam . is it possible to wire the lightbar so it comes on with hi AND lo beam??
Old Mar 2, 2007 | 01:05 AM
waltr's Avatar
waltr
Default RE: headlite rewire???
Yes, on this forum there is a diagram of how to do it. on the do it yourself help forum, electrical and lighting look for the topic--how to make your passing likes stay on when high beam is on. I believe that is correct.
Old Mar 2, 2007 | 01:10 AM
Bryan TTM's Avatar
Bryan TTM
take your lower fairin cap off (its the one under the ignition switch)....cut the orange/black wire on the spot switch and tie it into the orange on the acc switch
Old Mar 2, 2007 | 03:02 AM
BOARGAURD's Avatar
BOARGAURD
Actually just did mine. Cut the YELLOW from the spot switch and tie into the Orange/red tracer on the Acc button. Its been a while since Bryan has been into his but thats okay.
The directions are in the electrical section here (how to wire your spot lights)
Old Mar 2, 2007 | 07:48 AM
Bryan TTM's Avatar
Bryan TTM
thanks [8D]
relli's Avatar
relli
cool. so then the spots will be on with hi or lo beam on, correct???
Old Mar 2, 2007 | 07:52 AM
Bryan TTM's Avatar
Bryan TTM
YEP....but listen to Jason on what wires to cut/splice
Old Mar 2, 2007 | 07:56 AM
devious56's Avatar
devious56
[:-]You might want to keep in mind, that in some states (Florida for one) it is illegal to run your spots with the high beam. That is why they are wired to go off when the high beam comes on.
Devious [:'(]
Old Mar 2, 2007 | 08:42 PM
relli's Avatar
relli
yeah, but i believe that a headlite modulator is a must and it only works on hi beam and want the spots to compliment that for daylite riding. i usually dont run hi at nite unless im on the road alone
boardy
Mar 15, 2012 05:13 AM
OldNavy66
Electrical/Lighting/Alarm
Jan 23, 2012 09:18 PM
bobbyw47
Apr 27, 2011 12:38 PM
AndrewMichaelZ
Mar 7, 2011 08:37 PM
dietdewboy
Apr 27, 2008 04:59 AM
