Crank Runout
Old Aug 7, 2013 | 05:06 PM
soft 02's Avatar
soft 02
Originally Posted by 0ldhippie
Its not about gear drive cams or crank failure. Its about cam plate wear and oil pump failure.
Thats what happened to me with .004 and 118k on my bike. Cost me over 3k in parts to replace the crank. Pinion bushing was scored up and pump was toste and due to lack of oil wiped out the crank. **** happens. Most people trade up before they see stuff happen though.
https://www.hdforums.com/forum/gener...-job-pics.html
Old Aug 7, 2013 | 08:47 PM
bagman1's Avatar
bagman1
10-4 on the oil pump and cam plate wiping out at .005
Old Aug 7, 2013 | 08:51 PM
Wild Card's Avatar
Wild Card
any proof of this?
not doubting or disagree, just would like more info. If this is true, how and why would HD allow double that?
Old Aug 7, 2013 | 09:01 PM
soft 02's Avatar
soft 02
Originally Posted by Wild Card
any proof of this?
Moco just wants them to make it through the warranty period. Not that many newer bikes with 100k+. Its not an epidemic but something to be aware of.
Old Aug 7, 2013 | 09:09 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
any proof of this?
proof is when you have a shaft that is allowed up to .012 wobble, going thru a stationary hole, (your cam plate bushing) that has a .0015 clearance, with an oil pump bolted to it that runs an .003 tolerance, something has got to give sooner or later, is .005 going to do it? maybe later rather than sooner, depending on how its ridden, and remember this is something that is changing as the bike is ridden, so it slowly gets worse, and I know of few people who measure a failed motor, because at that point its a mute point. so not a lot of statistics really exist after the event. we all know the fix, and the cause is almost always the crank
Old Aug 7, 2013 | 09:18 PM
Wild Card's Avatar
Wild Card
That's what I am getting at. I just went through this on a '12 RK @ 5k miles. Litterally I am picking the bike up in the morning. Cam plate and oil pump shot, lost oil pressure and wiped out rod bearings as well.
I work on 1/2 million dollar centrifugal chillers for Trane...I have done a few overhauls. Tolerances are un acceptable. WHen I am done **** is perfect.
How does the MoCo get away with basically building and engine that will fail, it's basically built to fail no way around it.
Old Aug 7, 2013 | 09:23 PM
soft 02's Avatar
soft 02
One good thing is the OEM plate has some flex to it. Slap a billit SE plate or fueling plate and you will accelerate the problem. Don't mean to scare the op.
Old Aug 7, 2013 | 09:26 PM
nevada72's Avatar
nevada72
Mine went "out of spec" on my 2011 UGC at about 20k miles and 6k miles after a 107 build (100/120). The Moco would have replaced it with another pos crank. I opted to have it welded and plugged. They picked up the labor after the crank work cost.
Just sayin.
Old Aug 7, 2013 | 09:30 PM
bagman1's Avatar
bagman1
Well to prove it last year my pump was shot. A builder which shall remain nameless said my runout was at .004 which was ok he put in a se pump and cam plate. 2 k miles later the motor was vibrating a lot. Took it to another shop and the new am plate had signs of wear.The runout was .006 that's when I pinned and welded the crank. Yeah I was riding hard doing some bud outs etc.
Old Aug 7, 2013 | 09:48 PM
mgmmgm's Avatar
mgmmgm
my sense of security has faltered, guess I ride it until it coughs a crank.
