What's my windshield problem?
Old Aug 11, 2013 | 06:05 PM
Uncle Paul's Avatar
Uncle Paul
First you need to know where the wind is coming from...above or below.
When riding during buffeting first put your arm over your chest to block wind coming from below. Move it around a little to see if you can make the buffeting stop.
If that is the case you need to try lower wind baffles between the forks, or mounted on the fork tubes.
If your arm on chest routine does not make an improvement, then use your hand to act as a windshield extension. Move it around some to see if it makes the buffeting go away or bet better. You can also put your hand up near your face and helmet to feel if the wind is going back into your face, helmet or above it.
If this works, you can look for a different windshield. Maybe one of the curved ones.
Might need both.
This should get you on the right start to getting a quiet, enjoyable ride.
Old Aug 11, 2013 | 06:08 PM
GuNsLiNgEr420's Avatar
GuNsLiNgEr420
I have a 2013 Street Glide, I am 6'1 with a 38" inseam, I have tried at least 4 windshields and finally found one that has zero buffeting. I am using the Harley Davidson 10" Wind Splitter Windshield Part Number 57400092. It looks nice and is not too dark .. Go by the Harley Shop and pick up the loner.. They will let you use one for a few days for free. I did this and was back in the store in 2 hours after I hit the interstate and had zero buffeting at 60 and above.
Old Aug 11, 2013 | 06:10 PM
Chunker's Avatar
Chunker
I have the HD tinted 7" on mine but I am shorter, 5"7". Most buffeting, if you want to call it that, comes from the gap between the bat wing and lowers. Put your arm horizontal in front of your chest a couple inches and move it around a bit up and down. Likely you will feel the buffeting shift around some. Wind over the top of my windscreen just barely grazes the top of my helmet and none comes at the side of the helmet from the top. I also cut my stock shield down to about 8" and similar results.
Old Aug 11, 2013 | 06:30 PM
ZenGlide's Avatar
ZenGlide
Like Chunker's explanation above, I've found most buffeting comes from below. I put on some JSE fork deflectors to eliminate almost all of my buffeting. The deflectors actually work a little too good. I had to take them back off mid-summer to increase my airflow. They'll be going back on when it cools down some.
Old Aug 12, 2013 | 07:20 AM
gnewman's Avatar
gnewman
Thanks for all the input guys. I'm going to go out and do some testing later today or tomorrow and try and figure out where this wind is coming from. I'm also going to remove the visor from my helmet as well as put my brain bucket back on and see if I get the same results. Based on this I should be able to determine if the wind deflector is needed.
It's funny how a person goes from riding for 20 years without a windshield at all, buys a UC then has wind problems. WTF.
Do you have a link to these?
Old Aug 12, 2013 | 08:09 AM
bigfella48's Avatar
bigfella48
I have a 2013 Ultra Limited and am 6'1" with a 33" inseam. I have a Klock Works 8.5 windshield and have no buffering issues. I also wear a half helmet and all I get is clean fresh air.
Old Aug 12, 2013 | 08:16 AM
iwillfixthem4u's Avatar
iwillfixthem4u
Originally Posted by gnewman
I have a 13 ultra classic. I'm 6'2" with a 33-34" inseam.
I replaced the stock 12" clear shield with a 10" ultra from LRS (medium tint).
With the stock shield I get no buffeting but I'm looking through the glass a lot. I love the looks of this LRS but the buffeting is so bad I can't see 12 seconds ahead. I had to go back to stock. Now I measured and the LRS comes to the bottom of my nose which is where it should be. Why so much buffeting then?
im the same size as you and run a 8.5" Clear View with recurve and have no issues with fairing vents closed what helmet are you using?
Old Aug 12, 2013 | 08:28 AM
Deckman's Avatar
Deckman
http://www.jescustomaccents.com/
I have these on my 07 Street Glide with lowers and they work great. The real nice thing is these are the only ones that do not hit the lowers when locking your steering all the way to the right or left. All the "other" deflectors have a warning that they will hit the lowers. I have the same helmet as you and I have no problems with the visor on the helmet causing buffeting. I have a National Cycles 6.5" VStream windshield.
Old Aug 12, 2013 | 08:45 AM
Rick Lees's Avatar
Rick Lees
I've also found moving my knees towards the tank and back out will tell you where the wind is coming from...... I have a LRS 10 shield and its made a big difference but the wind doesn't bother me that much....still there but not bad
Old Aug 12, 2013 | 09:50 AM
Baffler1's Avatar
Baffler1
DECKMAN - Did you get the streetglide or the ultra wind deflectors? I only ask because I went to the link & the streetglide model does not say anything about working with lowers, but the ultra does.
