What's my windshield problem?
Old Aug 11, 2013 | 01:03 PM
gnewman's Avatar
gnewman
Default What's my windshield problem?
I have a 13 ultra classic. I'm 6'2" with a 33-34" inseam.
I replaced the stock 12" clear shield with a 10" ultra from LRS (medium tint).
With the stock shield I get no buffeting but I'm looking through the glass a lot. I love the looks of this LRS but the buffeting is so bad I can't see 12 seconds ahead. I had to go back to stock. Now I measured and the LRS comes to the bottom of my nose which is where it should be. Why so much buffeting then?
Old Aug 11, 2013 | 01:04 PM
gnewman's Avatar
gnewman
Let me also say I've tried different combinations of opening lowers and vents and that didn't help.
Old Aug 11, 2013 | 01:15 PM
CSMHOG's Avatar
CSMHOG
Not sure why. I use a simple 7" harley shield. I'm 6' and my nose is even with the top of shield. I ride all over the south eastern US like that with no issues. What type helmet are you using, could be a factor.
Old Aug 11, 2013 | 01:43 PM
gnewman's Avatar
gnewman
Had not thought about that. I'm using a bell pit boss with small visor. The buffeting starts above 60 mph. Below that its fine. I have always used a novelty brain bucket but recently switched to this mushroom. Wonder is that visor could be part of the problem??
Old Aug 11, 2013 | 01:53 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
May not be a solution for you, but I just added the chrome air baffle (about
$ 26) that mounts between the forks just above the front fender.
It definitely reduces the updraft that comes up over the fuel tank.
H-D used to put these baffle (in black) on most of their touring bikes but stopped several years ago.
I thought that it may have had something to do about engine cooling so I watched my oil temperature and I can see no difference there.
If nothing else, it's another piece of chrome!
Old Aug 11, 2013 | 01:56 PM
gnewman's Avatar
gnewman
For $26 I'd give that a try. Do you have a part #?
Old Aug 11, 2013 | 02:53 PM
Dobe66's Avatar
Dobe66
Part # is 58520-79TC. Page 319 of the 2013 catalogue.
Old Aug 11, 2013 | 04:08 PM
Charlie Fogg's Avatar
Charlie Fogg
The visor could definitely be contributing. I have a half helmet with a visor and had terrible buffeting. I took the visor off and greatly reduced the problem. Unfortunately I do not often wear a helmet due to the hot climate here so I never experience any buffeting. 10" HD wind splitter works well for me too.
Old Aug 11, 2013 | 04:36 PM
Lowcountry Joe's Avatar
Lowcountry Joe
I am sold on the National Cycle Vstream shields. I use the 12" model on my bike and the wind hits just at the top of my head. I can see over it fine and I am 5'10". These things are literally bullet-proof. Great shield!
Here is a link:
http://shop.nationalcycle.com/perl/c...h_model=hr-081
Old Aug 11, 2013 | 05:57 PM
mkguitar's Avatar
mkguitar
FYI I installed one of these on my Pal's 2011 FLHTK without him knowing...about 500 miles down the road I asked him how the wind was...sucks he says, just like always.
could be if you don't know the part is there---- you won't notice a difference.
the helmet if you wear one is a huge part of your wind experience.
when in hostile territory I wear a HD branded 1/2 with a little ducktail on the back- only one I ever had that didn't lift on the strap or bobble around.
I have a pretty good wind experience riding, I cut my windscreen so the top edge appears to intersect the road about 40' ahead ( cut the bottom, hidden, edge with a rotozip or jigsaw).
I also use the adjustable fairing deflectors to control and channel wind into the cockpit, this reduces a pressure differential
mike
