Tank emblem removal
Old Aug 20, 2013 | 08:29 AM
christo651's Avatar
christo651
Default Tank emblem removal
I have seen some posts about removing the tank emblem with fishing line, but mine has 3 screws holding it on. Any suggestions? other than just removing the screws. What is it screwed to? are there mounting holes on the tank?
Old Aug 20, 2013 | 08:36 AM
mikeo33y's Avatar
mikeo33y
id like to change my tank emblem too. I have a 2013 UC and i hate it. Was wondering also how the emblem is removed. I always thought they were glued on
yzergod's Avatar
yzergod
Screws hold emblem to a backing plate. That plate is held on with adhesive. Read this thread for step-by-step instructions. HTH.
Old Aug 20, 2013 | 09:52 AM
RaceFace's Avatar
RaceFace
As said above, take the screws out, the emblem will come off and there will be a backing place that has double sided tape on it. THAT'S what you will need to remove with fishing line from the tank. If you plan to use it again, take it easy with the place, they bend really easy.
Old Aug 20, 2013 | 10:51 AM
Herksuper's Avatar
Herksuper
Blast it a little with a heat gun to soften up the tape and the line will go through like butter.
Old Aug 21, 2013 | 11:30 AM
christo651's Avatar
christo651
Thanks for the help. I was able to remove the emblem and clean behind it, that was the source of frustration. For now they are back on, but I figure since I messed with the tiny screws they will be falling out soon enough and I will go badgeless at that point. On another note, an old soft bristle toothbrush does great removing old wax around the other emblems and the one on the gas tank lid. Who knew the detail that was there 13 years ago.. I also tried the pledge with lemon trick, but must confess I like silicone glaze wax better. I had an old bottle of the amway stuff and it really was better than the mequires I tried first. Just gotta figure out how to get more since the bottle is like 15 years old.
converted
Mar 14, 2013 02:40 AM
aamodt22
May 29, 2011 02:07 PM
dusk883
Aug 28, 2009 09:06 AM
genedjr
General Topics/Tech Tips
Aug 18, 2009 09:43 AM
bensonjv
Sep 7, 2006 06:37 PM
