Recommendations for Brake Bleeder
Old Aug 22, 2013 | 07:53 PM
Skippy97's Avatar
Skippy97
Default Recommendations for Brake Bleeder
Hey All,
Any recommendations on a brake bleeder? Kinda hard to figure out all the differences out there. I've seen bleeders from $24 to $150. What's the difference?
Want a bleeder for a touring bike with ABS.
Thanks!
Skippy
Old Aug 22, 2013 | 08:02 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Check out Speed Bleeders.......
Old Aug 22, 2013 | 08:21 PM
SBates08's Avatar
SBates08
I use a Mityvac that I picked up at Harbor Freight for about $30. It has more than paid for itself. Any of them should work. No need to spend a fortune on one.
Old Aug 22, 2013 | 08:41 PM
The Q's Avatar
The Q
Speed Bleeders are the way to go!!! Very simple one man operation once installed. Installation is simple too. Remove old bleeder screw install Speed Bleeder and bleed away!!!
www.speedbleeder.com
Old Aug 22, 2013 | 09:41 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
2feet of clear tubing and a jar. Every bit as good as a speedbleeder, better than a vacuum bleeder, and a whole lot cheaper.
Old Aug 22, 2013 | 10:14 PM
silverado636's Avatar
silverado636
Mityvac #MV8500. Works excellent. It may cost more than a Harbour freight one but what did you pay for your bike. Thats right it wasnt a cheap investment. Buy good quality tools to go with your bike.
Old Aug 22, 2013 | 10:22 PM
2kids3pets's Avatar
2kids3pets
What he said.
Old Aug 22, 2013 | 11:09 PM
chris h.'s Avatar
chris h.
So, the speed bleeder kit basically just has a check valve where it screws into the bleeder port. I really don't see anything wrong with having a long clear tube, as long as you get enough fluid pumped through the tube, there's no danger of air sucking back in. Literally the same way we bleed brakes on my jet.
Old Aug 23, 2013 | 04:48 AM
katobird's Avatar
katobird
What he said....
2 feet of clear tubing and a glass jar.....
never had a problem
Old Aug 23, 2013 | 04:59 AM
grbrown's Avatar
grbrown
Red face
I've been bleedin' brakes since the 70s and have yet to find a truly reliable method. Some of the aftermarket magic tools work some of the time, but will lighten your back pocket much more effectively. The old way still works, despite 'modern technology'. The most important tools are patience and even more patience! There have been times when a brake has bled fine before I am ready, others when it has taken an age.
Your best way ahead is to save your dough, think calm thoughts, pray to all your Gods and take your time! Stop over-thinking and make a start. Nothing else seems to work......
